Inventor Forum
Help with smoothing out a converted wireframe to 3D part
8 REPLIES 8
Message 1 of 9
1506 Views, 8 Replies
Recently I had to convert a .stl to an .ipt, to do this I converted the .stl to a .dxf and then stitched to wire together. Now I need to make a detailed drawing of the part, but the surfaces are not smooth, anyway I can fix that? All I was able to find while researching was how to smooth lofts, which this is not.
Details: Autodesk Inventor Professional 2013
(I had to delete the sticthings to make the file small enough)
8 REPLIES 8
Message 2 of 9
JDMather
1. You did not need to convert to dxf
2. You can convert your Inventor surface model to a solid model using the Sculpt command in Inventor and selecting the surface body.  Sculpt.PNG
3. Rather than use an stl (faceted faces) for something this simple - I would create it over from scratch in Inventor.
Message 3 of 9
in reply to: JDMather
Thank you for the answer, and your time.
Message 4 of 9
JoAnn_Hogan
Are you bu any chance designing a CO2 gas cylinder powered balsa wood F1 car?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 5 of 9
in reply to: JoAnn_Hogan
Not balsa wood but plastic. It is planned that it will be printed on a 3D printer. To be specific a Makerbot, which is why it was in an stl format.
Message 6 of 9
JDMather
Do you have the original file (before it was ever saved in stl format)? *.dwg? *.dxf? *.ipt?
Message 7 of 9
No, that is why I needed to convert it to a solid body. The problem is the school where I study has it so that any deleted file is directly removed, completly by-passing the recycling bin, as then there is no hopes of recovering deleted material.
Message 8 of 9
JDMather
Two words - Thumb Drive.
Message 9 of 9
JoAnn_Hogan
Because you are designing a CO2 car I thought you might find this interesting. Top Gear SA has a "F1 in schools challenge" and my company is part of this project. Go have a look at it, you might find it interesting: http://www.modena.co.za/news/f1-in-schools-technology-challenge/19
Jo - Ann
