Laurence Yeandle wrote:
> There is a problem with Ext30 and WP23, this may well be dependant on some
> earlier geometry.
> When you consider that there are no less than 28 features dependant on
> Ext30!
> The gravity of the problem is mind boggling.
> I would seriously consider remodelling the whole part, removing material
> instead of adding feature on to feature, even features without editing well
> before Ext30 of the model will not survive rebuild.
> After much messing with errors on my own models I now include as much of the
> detail in the first sketch and base all of my workplanes etc of this. Yes
> this takes time.
> All IMO of course, I know its not want you want to hear, sorry.
I would agree with Laurence that remodelling would help this part. When
I opened the part, sketch doctor reports sketch 23 (split3) & 28
(sweep3) have constraints to unresolved reference geometry. This tends
to add to the instability of the part, particularly since sweep 3 is
related to extrusion3, which is the diameter you suggested changing that
causes the crash.
An added 2¢ worth of opinion, I treat edge tapers like fillets and
chamfers, I place them all after the part is completed. When I edit a
part later, I move the EOP marker above the fillets, chamfers and
tapers, do the edit and then move it back down. This allows all my
sketches to be resolved to square edges and corners. Much easier
construction of the model.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4201 drivers
Dell UltraSharp 19" LCD
