Inventor Forum
Help Item(i) not found
19 REPLIES 19
Message 1 of 20
899 Views, 19 Replies
my code don't work!!! Item(i) not found.
Imports Inventor
Imports Inventor.ObjectTypeEnum
Imports System
Imports System.IO
Imports System.Type
Imports System.Activator
Imports System.Math
Imports System.Runtime.InteropServices
Public Sub Export()
Dim oBom As BOM = oAsmDoc.ComponentDefinition.BOM
oBom.PartsOnlyViewEnabled = True
oBom.SetPartNumberMergeSettings(True)
Dim oBomView As BOMView = oBom.BOMViews.Item("Parts Number")
Dim oBomRows As BOMRowsEnumerator = oBomView.BOMRows
Dim oCompDef As ComponentDefinitionsEnumerator
Dim i As Integer, j As Integer
For i = 1 To oBomView.BOMRows.Count
oCompDef = oBomRows.Item(i).ComponentDefinition.Item(1)
Next i
End Sub ...
please help me
19 REPLIES 19
Message 2 of 20
Get rid of the i after next.
T.S.
Message 3 of 20
error in
oCompDef = oBomRows.Item(2).ComponentDefinition.Item(1)
inventor stop, and error:
MissingMemberException
ComponentDefinition" for type "BOMRow" not found
Message 4 of 20
What are you trying to accomplish with this code?
Message 5 of 20
I think the end of this line should be "Part Number" not Parts
Message 6 of 20
next i get
oParName = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
oPar = oCompDef.Parameters
for all parts
Message 7 of 20
Yes, I have already corrected
Message 8 of 20
if you want the iprop for part number try this instead.
oParName = iProperties.Value("Project", "Part Number")
Message 9 of 20
Imports Inventor
Imports System
Imports System.IO
Imports System.Type
Imports System.Math
Public Sub Test()
Dim ParName() As String = {"d_M", "d_A", "d_B", "d_C", "d_D", "d_E", "d_F", "d_G", "d_L", "d_N", "d_S"}
          For j = 0 To UBound(ParName)
                       Msbbox (oBomRows.Item(j).ItemQuantity)
          Next
Next
End Sub
Message 10 of 20
The above may not work in the context of your rule.
Message 11 of 20
Are you just trying to cycle through you BOM listing part name and quantity?
Message 12 of 20
Imports Inventor
Imports System
Imports System.IO
Imports System.Type
Imports System.Math
Public Sub Test()
          Next
Next
End Sub
 Did I understand correctly?
Message 13 of 20
Yes
Message 14 of 20
Are you just trying to cycle through you BOM listing part name and quantity? - YES
Message 15 of 20
DimoDocAsAssemblyDocument
oDoc=ThisDoc.Document
DimoBOMAsBOM
oBOM=oDoc.ComponentDefinition.BOM
DimoBOMViewAsBOMView
oBOMView=oBOM.BOMViews.item("Parts Only")
DimiAsLong
Fori=1TooBOMView.BOMRows.count
DimoRowAsBOMRow
oRow=oBOMView.BOMRows.item(i)
DimoCompDefAsComponentDefinition
oCompDef=oRow.ComponentDefinitions.item(1)
DimoPropSetAsPropertySet
oPropSet=oCompDef.Document.PropertySets.Item("Design Tracking Properties")
oUPropSet=oCompDef.Document.PropertySets.Item("User Defined Properties")
MessageBox.Show("#: "&oRow.ItemNumber_
&" Quantity: "&oRow.ItemQuantity_
&" Part: "&oPropSet.Item("Part Number").Value)
Next
RuleParametersOutput()
InventorVb.DocumentUpdate()
Message 16 of 20
I hate it when pasting removes the spaces.
Message 17 of 20
Here without missing spaces
Message 18 of 20
You will not need this line
Message 19 of 20
do not work. I work in Visual Studio
Message 20 of 20
I dunno what that is, a VBA editor of some sort.
T.S.
