Good morning everyone, How to give a specific name and number to a frame generator parts (members)? thank you all
Solved by CGBenner. Go to Solution.
Thank you very much for your answer ,but could you please explain more or could you please send me a file example ,if it is possible, because i tried a lot of thing and it did not work probably, Thank you
@Sahar.IbrahimK54R9 @Mario.VanWiechen
You can manage Frame Generator file naming defaults in Application Options, under the File Tab \ File Naming Defaults
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thank you very much for your help, can i aske you also ,why when i change the dimension of the Skelton, the frame generator does not updated with the new dimensions ,Thank you
