Can I open a fusión 360 file (f3d) in Inventor?. What is the best way to export from fusión 360 to Inventor.
Thank in advance
Solved by schneik-adsk. Go to Solution.
Kevin,
I have not tried this, but once the part is in Inventor, does it show up as a base solid?
If the part is edited in Inventor, if we need to edit later, do we export to step to get it back to Fusion or is there another way?
Kirk
Kevin,
I was able to get it to Inventor and make an edit. Then going back to Fusion, I uploaded a new version. Now I want to open this new version in Fusion. Don't see a way to open the new version. I can preview it, just can't open it in F360.
Kirk
Hello...!
Thank you for your tip. It really worked and I made what I needed.
My best regards from Portugal:
João Carvalho.
