First sketch rotates coordinate system.
YannickEnrico
Advisor Advisor
Message 1 of 15
YannickEnrico
Hi there!
After updating to Inventor 2017 I've noticed something in the part environment that has changed.
After creating a new part and pressing s to make my first sketch, it rotates the whole environment so "top" on the viewcube is faced towards left, front is faced right, while right is faced up.
I'd like it to stop rotating, or at least rotate correctly to this orientation:
Top = Up
Front = Left
Right = Right
on the isometric viewcube.
Things I tried:
- Changing the default orientation so Z axis is perpendicular to Top
- Disablingand enabling "Look at sketch plane on Sketch Creation and Edit"
Any solutions to this?
Best regards
Yannick Nielsen
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Replies (14)
Message 2 of 15
mdavis22569
Hi and welcome to the forum ....
quick question ... What are you using for your first sketch plane?
Can you make a quick screencast to show us what you're seeing?
Mike
Mike Davis
Message 3 of 15
YannickEnrico
This is what I'm seeing. So I have to place my sketch on the vertical plane if I start drawing the bottom.
This is counter intuitive, and I would like for it to be the horizontal plane instead.
As stated above, I tried changing the viewcube ("Current view as...."), and I succeeded in changing the vertical axis to be Z instead of Y - But the whole thing still rotates so the Top "lies down"
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 4 of 15
mdavis22569
Can you not use a different starting plane ...
However I have a different question ...   Why does the top position on the Cube matter on how it's set?
I usually draw the model as needed for exporting ...and just set the top, or the front when I'm done...
Mike
Mike Davis
Message 5 of 15
stuart_smith82
Just a thought but there are multiple options when aligning to a view in inventors application options.
Can you check your settings and try alternating between the two look at behaviours and see if this helps:
Stuart Smith
Group Data Management Consultant Graitec UK
[email protected] | www.graitec.co.uk
Blog: https://www.graitec.co.uk/blog/blogger/smith
Graitec Manufacturing Blog: https://www.graitec.co.uk/blog/categories/mechanical
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Message 6 of 15
YannickEnrico
I can use a different starting plane, but I wanted to work the intuitive way.
I wanted to avoid changing the cube around all the time.
Back in my old company (inventor 2016 and prior) the first sketch didn't behave like that. And a friend of mine who just updated to inventor 2017 doesn't experience it either.
It's more of a QoL thing than a necessity. But it would be nice to figure out.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 15
YannickEnrico
Changing those didn't change its behaviour
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 8 of 15
jeanchile
Mike,
I too am frustrated by this and can offer our biggest reason why it matters:
We often interface with other industries and their software (Navisworks, Civil, etc.). I guess since the beginning of AutoCAD years ago it was decided that the XY plane would always be the plane they draw their 2D plans on (with the positive Z axis being in the up direction) and North being "up". When our Inventor based models are loaded into other programs they come in the same way whether we've changed them or not. Meaning if we didn't use IV's XY plane as the ground plane with the Z direction "up" our models have to be "transformed" in some way in the software with rotation and offset dimensions to get lined up. It is a pain in the butt. Even the North arrow in Inventor needs to be left in the default position or the rotation in that axis is off.
Not to mention that if all of my employees don't follow the same protocol, all of our skeletal modeling and constraining techniques fall apart.
I have a 3D mouse with programmable buttons. One of those buttons is set to start the sketch command and then immediately hit the home view command so it rotates back to where it was when I started.
This is another one of those things that Autodesk changed between 2013 and 2015 (we skipped installing 2014) that is annoying and made things more difficult for us but most users like yourself probably wouldn't care about.
Inventor Professional
Message 9 of 15
mcgyvr
Just open the template file.. Set the view cube how you want it and save the template..
Message 10 of 15
Curtis_Waguespack
Hi yannick,
Concerning the view cube "tipping over" on the initial view creation you might be trying to modify the behavior mentioned in points 5 and 6 of this post:
https://forums.autodesk.com/t5/inventor-forum/viewcube-orientation-on-document-create-application-op...
I hope this helps.
Curtis
Message 11 of 15
YannickEnrico
Opening my template my viewcube sits correctly.
However, creating the first sketch, my viewcube rotates as shown on the picture.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 12 of 15
YannickEnrico
Hi Curtis
Thanks, but this isn't the issue. I have no problems with the view cube initially.
It rotates to something other than "home" view when I start the 2D sketch command.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 13 of 15
YannickEnrico
After testing some more, I discovered that it will always rotate so the UCS faces as in the picture attached.
Is there no way to come around that? Because I'd prefer Z to be up rather than Y
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 14 of 15
stuart_smith82
I think there may have been misunderstanding with what you were asking from everyone trying to help you.
When you select new sketch in a empty part the view will always rotate to have Y axis pointing in a positive vertical direction in relation to your screen.
Unfortunately there isn't any way to change this without I assume iLogic or API.
We have customers with similar issue where there products are essentially facilities and must be created with real world orientation and location taken into consideration at all component levels.
Another option is to have templates setup with predefined sketches on places and a description in template to guide user for correct selection when creating components e.g standard XY.ipt, standard XZ.ipt etc.
Stuart Smith
Message 15 of 15
YannickEnrico
Such a shame. It may have come down to template, then, in my old company.
Thanks for coming with that answer. Even if it didn't solve my problem, it made it clear that there currently is nothing to do about it
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
