Hello, all.
We have a part that was generated as a loft in Inventor 2017. It is a large panel that will have a graphic "skin" applied to it. It is also a compound curved surface.
We are trying to generate a mesh model of just the top face, so we can unfold it to give us a "flat pattern" to send to the graphics manufacturer.
The closest I can come is to perform an analysis on the part, which will allow me to display a mesh on that surface. However - I can't do anything with it. Is there some way to extract this mesh in such a way that I can take it into 3DS Max (or other) and unfold/unwrap it? Have attached base solid, which was derived, so (2) files attached. 1362-111_052.ipt - model for which we need surface mesh
Test 17.ipt - base model for derivation
Any alternative workflow approach also much appreciated.
Thanks!
Solved by JDMather. Go to Solution.
I was able to Unwrap using free Autodesk MeshMixer.
You might also investigate -
Note: The above example was one that I had already recorded - it is not using your geometry.
Another example.
But my original image was of your geometry.
Thank you! This is doing the trick.
Also found another "unfolder" called "Exact Flat" that works well, and is free:
https://www.exactflat.com/online/
Hi! Just to clarify a bit, ExactFlat is free to try but not free. Inventor team is working on a command called Unwrap. If you are interested, you can sign up Inventor Beta (https://bit.ly/InventorBeta). You will be able to try the workflow in an install-free environment and discuss the workflows with the project team members.
Many thanks!
