Hi. Inventor 2019.3 and the problem is; (not everytime and not in every idw drawing with the same templete but mostly) with idws that have section views, when exporting to acad dwg (of any version); with "base view scale model drawings" or with other options nothing changes; there are strange unique scaled drawing views on layer 0 of dwg, and lost hatchings.. it is like the pictures attached, and hope to be solved in new update. Thanks.
Solved by hrnkilic. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! I vaguely remember seeing this issue before. It has something to do with wrong scale of view geometry getting exported. Just for a test, could you try using attached .ini configuration file to export the drawing to dwg?
Many thanks!
Many thanks from me sir.
I've exactly done the same thing; created the same .ini file from options dialogue form for exporting Acad DWG ; after posting my first message. It is now ok accept one thing; the scales of hatch objects are not exported correctly to dwg file from idw sheet. Now I'm searching for this issue. Thanks again. Regards.
Good morning.
I'm glad I've found this thread because we face the same problem in our company. When my friend exports the drawing, the erratic veiws are present, but when I export the same drawing, it is exported perfectly. There is no difference if we try Export to DWG or Save As DWG. We tried to use my export configuration file and also your file BetterSpline.ini.
The strange thing is, that Task Scheduler works well and exports the drawing on my friend's PC without an issue.
Right now we have 3 of 15 people in our company fighting this problem.
Any ideas, help?
Thank you.
Milan Zikmund
Hi Milan,
I am sorry I don't know how the problem started. The fact that you mentioned some machines work but some don't. Maybe there is some local factor. Please make sure you install the latest update to your Inventor. And, try using Inventor Reset Utility (All Programs -> Autodesk -> Inventor xxxx -> Tools) to reset all the settings back to install defaults.
Many thanks!
I have the same problem at exporting to dwg file. How to proceed to replace acdb.pat file?
The strange thing is that after restart everything seams OK. Where is the problem?
Hi, yes when you think that the problem has gone, after restart it remains the same..
Try this; I solved the problem by this way.. (important point is; "paste content of Clipboard at the end of the file" )
Autodesk® Inventor®: Export dwg or dxf creates additional geometry and hatch is missing
Hi! The behavior is defective. But, somehow we cannot reproduce it. Are you able to reproduce it persistently? Did you try Inventor Reset Utility (All Programs -> Autodesk -> Inventor 20xx -> Tools). This will reset all Inventor settings back to install default. You will lose all customized settings except templates, as a result.
Many thanks!
Hi Dear Johnsonshiue.
I couldn't solve it permanently. Sometimes the problem appears, sometimes does not; for the same file. Changes in acdb.pat & acdbiso.pat files do not affect in most cases. I didn't use reset utility of the application. I accommodate myself to work with it (: Thanks.
And I tested this solution and it (seems to be) solved;
First open Inventor application, and then open idw file within the application.
Opening the idw file with double clicking it in the windows (explorer) browser causes the problem.
