I'd like to export all the components as a parasolid. I'd like to import the parasolid back as multiple bodies into a new part file. A multibody part file is what I'm after. It seems when i try to do that, it creates an assembly structure for me again. I don't want that. How can I create a multibody part file from an existing assembly?
Solved by pcrawley. Go to Solution.
Solved by MkEHWD. Go to Solution.
Hi, I'm not sure if this what you want but let me know :
1- Create a new part
2- Click on "Import" in the "Create" section
3- Import your parasolid
You are gonna have 1 part with all the Solid inside without being inside an assembly.
Is there a reason you need to export as Parasolid if you only want a multibody part file in Inventor?
Assuming you don't need the Parasolid file, you can make a multibody solid from an existing assembly as follows:
Done.
