Inventor Forum
Error in inventor undo folder, how can I solve this?
11 REPLIES 11
Message 1 of 12
25979 Views, 11 Replies
Buenas el error que tengo es este ¿cómo lo puedo solucioar?// Hello this is the error How can I solve this?
11 REPLIES 11
Message 2 of 12
mpatchus
Go to your Inventor options and look at the file tab..
Undo should read ...
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 12
jletcher
I make a folder under my C drive called inventor undo and I map to that. This way if the error comes up again I can go to that folder and delete everything and restart inventor. All it is telling you is there is no more space for the undo files to go..
Message 4 of 12
the undo file looks like that but it still doesnt work ...plz help
Message 5 of 12
skhuam
Make sure your C drive got enough space, at least few gb free space. It could be one of the reason fot this message to pop out.
Message 6 of 12
JDMather
in reply to: skhuam
I just got this error on one of my machines (r2013) and Inventor doesn't launch.
Cleaned the referenced Temp and still no luck?
Message 7 of 12
mpatchus
in reply to: JDMather
How much free space do you have?
Recycle bin empty?
Inventor 2025 Beta
Message 8 of 12
JDMather
in reply to: mpatchus
Whoa,
I thought I had a monster HDD that would never fill up, but that was it.  I had no idea that it was almost full.
Now I've got to spend some time taking out the garbage that wasn't in the Recycle bin.
Message 9 of 12
copy the link that the message box shows and open that link. It is usually hidden so cant be accessed directly. Manually delete all the files in the folder and you are good to go!
Message 10 of 12
nate_k
The fix for the missing error message will be released in a future service pack.
Nate Kozlowski
Software Engineer - Inventor
Message 11 of 12
i had the same error and it was couse the temp folder was full. I resolve it by installing "CCleaner" and running it.
Message 12 of 12
Emptying recycle bin worked... thanks!
