Inventor Forum
End treatment with round tubes, frame generator
10 REPLIES 10
Message 1 of 11
1859 Views, 10 Replies
Is it possible make end treatments to round tube that it will fit round tube, end of the tube isn't straight like in the picture?
10 REPLIES 10
Message 2 of 11
I did manage to do it by copying to surface bodies and trimming with surface face. Is this the only way? Lot of work if you have more complex frame than this my example.
Message 3 of 11
JDMather
Download a trial of 2014.
Message 4 of 11
in reply to: JDMather
So it is only way with 2013? I have to do it with 2013 because we have that in school and can't open 2014 with 2013.
Message 5 of 11
JDMather
Unfortunately I think that is the only way in 2013.
Message 6 of 11
Ok, thanks!
Message 7 of 11
JDMather
Wait, just to make sure - you are referring to bent tubes right?
Round tubes should trim, but not bent (round) tubes (without the extra copy object surface work)
Message 8 of 11
I mean trimming tubes to each other. Tubes have straight section before end treatment. They have bends also but not where I want to trim them. Just like in the picture, I want to trim that straight tube to other tube.
Message 9 of 11
Can you add use tube-fittings on the ends (elbows and T-piece) ?
Message 10 of 11
JDMather
The Frame Generator creates an assembly.
You can add components to any assembly.
Message 11 of 11
A combination of 'trim to frame' & notch can get the result you want in 2013.
I've got a negative offset on one of the frame members, so that it stops short of halfway into the other tube & then I've used the notch command.
Autodesk Customer Advisory Groups
