Inventor Forum
Dimension arc length
13 REPLIES 13
Message 1 of 14
554 Views, 13 Replies
Is it possible in Inventor to dimension an arc's
true length?
13 REPLIES 13
Message 2 of 14
In a sketch, I mean.  I think I've done it on
drawings.
arc's true length?
Message 3 of 14
In an IDW its as easy as a RMB before placing the dim,
In an IPT its not doable without math formulas
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Brian Mears" wrote in message
news:57DE2AC54F66919B2C27918860694D40@in.WebX.maYIadrTaRb...
> Is it possible in Inventor to dimension an arc's true length?
Message 4 of 14
Crap. That's how I had to do it in MDT. Here's a vote for an 'arc length'
sketch dimension in a future release....
Brian
"Drew Fulford" wrote in message
news:6CA593A9E0B4568E85095008E333208F@in.WebX.maYIadrTaRb...
> - drew
Message 5 of 14
"Here's a vote for an 'arc length' sketch dimension in a future release...."
Amen, brother!
Message 6 of 14
There is an example in Cf on how to do it in part mode..
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
> - drew
Message 7 of 14
oops hit enter too soon...
The vertical line shows the arc length
Sean Dotson, PE
"Sean Dotson" wrote in message
news:381D66E87B7A7998CE253DC130329302@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > - drew
Message 8 of 14
I'd be working the other way... you use the angle and radius to find arc
length; I would use radius and arc length to find the angle. Can you post
an example of that? I just imported my adjustable arc from MDT, but I'd
like to see your solution. Thanks...
Brian
news:F7066DFE262584F8DDEDF2584945C0F0@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Sean Dotson, PE
> > > - drew
Message 9 of 14
I posted an example on 05/13/02 "Chord length of arc"
See if that helps.
Mike
news:E70F095B5B48BC3067FE69421D094A67@in.WebX.maYIadrTaRb...
> Brian
> > Sean Dotson, PE
> > > Sean Dotson, PE
> > > > - drew
Message 10 of 14
see CF
Sean Dotson, PE
> Brian
> > Sean Dotson, PE
> > > Sean Dotson, PE
> > > > - drew
Message 11 of 14
Which one is the arc length? Looks like the leader dim is the radius, no? If
you change the angle, it still keeps the same dim.
~Larry
> Sean Dotson, PE
> > Sean Dotson, PE
> > > - drew
Message 12 of 14
The vertical line is the arc length in both examples. In the first example
change the angle or radius to get the length. In the second change the
length or radius to get the angle...
Sean Dotson, PE
"Larry Caldwell" wrote in message
news:3632CB02BE858051864756CCC8D2D404@in.WebX.maYIadrTaRb...
If
> ~Larry
> > Sean Dotson, PE
> > > Sean Dotson, PE
> > > > - drew
Message 13 of 14
Naturally I saw that only after I posted ... Duh! I picked on the dim ...
sure'nuf ... it was named arc length.
~Larry
news:7064FE7FB96C3A62932CFE3AC74368D8@in.WebX.maYIadrTaRb...
example
> Sean Dotson, PE
no?
> If
> > ~Larry
> > > Sean Dotson, PE
> > > > Sean Dotson, PE
> > > > > - drew
Message 14 of 14
Personally, I vote that the code for the drawing arc length be copied and
used in the Part model
IMHO.
Bill Bogan
news:962DDAF94B9E27DF72F57DF1799598B4@in.WebX.maYIadrTaRb...
> ~Larry
> example
> > Sean Dotson, PE
> no?
> > If
> > > ~Larry
> > > > Sean Dotson, PE
> > > > > Sean Dotson, PE
> > > > > > - drew
