Hello
I work for a company that 90% of the time uses Front, Top & Side view.
By default they are named View1, View2 & View3.
We always re-name them - Elevation View, Plan View & End View.
Is there a way to create a button to rename each view.
"Elevation" button - click it and it renames the view as Elevation View.
"Plan" button - click it and it renames the view as Plan View.
"End" button - click it and it renames the view as End View.
Thanks.
Doug
Simple answer. iLogic. See if the attached link gets you started and helps.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
