Inventor Forum
Creating decals with transparent background!
10 REPLIES 10
Message 1 of 11
12451 Views, 10 Replies
Do anyone know how to create a decal with a transparent background? At the moment I need to save the bitmap image's background colour as the colour of the part that I place it on. This obviously prevents you to reuse a standard decal on different coloured components.
I have tried different image formats that I created in Photoshop and gave them a transparent background, but when I place it in Inventor the background shows.
10 REPLIES 10
Message 2 of 11
After you place the image in the sketch,
right-click the image in the browser (child of the sketch) and select
properties. In the Properties dialog box, check Use Mask. The pixel in the lower
right corner of the image becomes the transparency mask color.
If you start the Image tool inside a sketch,
right-click and select How-To from the context menu. (Good technique for
exploring new tools).
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Do
different coloured components. I have tried different image formats that I
Message 3 of 11
Thanks a million! Battled more than a day trying to find an answer.
Message 4 of 11
JDMather
Sounds like you got it, but make sure you do not use jpg as the image source as even what appears to be a solid bacground color will actually be different shades which means it will not completely hide.
Message 5 of 11
Ye, I normally use bitmap format so I will not have that problem.
Thanks again.
Message 6 of 11
PNG's are much more compact and are
lossless.
Ye,
I normally use bitmap format so I will not have that problem. Thanks
again.
Message 7 of 11
dbcox
Hello everyone,
I am bring up an old thread here, but I found it while searching for a solution to my problem.  I have a decal with standard Arial font and a small logo.  It is all black.  I am applying it to a coiled surface.  Everything is working great, even the transparency, with one exception.  Some of the logo, and all of the fonts, are outlined with a thin white line.  How do I get rid of that?
The logo was created in Photoshop and I've tried both PNG and BMP formats.  I also tried a transparent GIF, but still had to turn on transparency in the image file properties.
Thanks!
Message 8 of 11
mcgyvr
in reply to: dbcox
@dbcox wrote:
Hello everyone,
Thanks!
@dbcox Can you post the image here?
You probably just need to clean up the image some.
Message 9 of 11
dbcox
in reply to: mcgyvr
mcgyvr,
Thanks for the quick reply.  I have attached an example that I created from the original.  I cannot paste the original because it has my client's information and part numbers on it.  I tried this one and it has the same issue.  I should also clarify that the issue appears on screen and in a rendered image.
Message 10 of 11
mcgyvr
in reply to: dbcox
@dbcox
Seems to be a limitation/issue with Autodesks "mask" functionality..
Its not "exacting" enough or something..
If you use a darker background color you can just about cancel out the effect..
Use a dark gray background with black text and you don't notice it at all..
With a transparent png autodesk seems to see a white background and when masked you see the white..
With a red background/mask you see a red border around everything..
Message 11 of 11
dbcox
That worked perfectly! Thanks!
