Inventor Forum
Creating a rescaleable scetch to use as a logo "stamp"
7 REPLIES 7
Message 1 of 8
322 Views, 7 Replies
well, the title more or less contains my question: I want to create a sketch and save it somehow so that i can load it into other projects and etch out a quick logo.
7 REPLIES 7
Message 2 of 8
salariua
Brian Ekins has a brilliant post on this:
http://forums.autodesk.com/t5/inventor-customization/assign-multiple-parameters-with-the-same-value/...
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 8
Logos_Atum
in reply to: salariua
Hello there,
there is a non- Ilogic solution for this too.
You could use the same base unit throughout the sketch and dimension in fractions or multiples of this base unit parameter.
You could define a parameter named scale and say it´s 100 mm for example.
Whenever you dimension you would use something in the way of
height= 3xscale
width=5xscale
depth=0,4xscale
Whenever you need to change the overall size you just need to adjust the "scale" parameters initial value and I am sure you could align it to the drawings desired scale easily.
Kind regards
Daniel
Dogs aren´t flammable.
Message 4 of 8
salariua
in reply to: Logos_Atum
Yes, Daniel is right. It might be cumbersome if you've allready modeled the logo to change all the parameters but you could export them to xml, edit them with something like notepad where you can do search/replace and import it back.
Adrian S.
blog.ads-sol.com
Message 5 of 8
Cambo_Slambo
Could you also make the logo sketch a "block" and scale it it suit when using it?
You can easily copy the block from part to part or if you have a part template setup have it in there then it will always be there when starting new parts.
Message 6 of 8
Logos_Atum
in reply to: Cambo_Slambo
I am not sure if the logo, saved as a sketched symbol, can scale along.
I though I read something in the way, but it was quite some time ago.
If I happen to remember I´ll hit you up
Kind regards
Daniel
Message 7 of 8
salariua
You can't control the scale value with a parameter.
Adrian S.
blog.ads-sol.com
Message 8 of 8
Cambo_Slambo
I think you are correct. I was sure I scaled a block but it seems you cant. You can mirror one though.
Maybe a feature for the idea station? Scaleable blocks.
Autodesk Customer Advisory Groups
