Inventor Forum
Copy ilogic Form via API to several documents
8 REPLIES 8
Message 1 of 9
1439 Views, 8 Replies
I created an iLogic Form (and some code) in my Inventor drawing template. Now I want to copy this objects by a vb.net script to other drawings. The copy funktion for the iLogic code and the triggers is working fine. But how to copy the Form?
Has anybody an idea?
8 REPLIES 8
Message 2 of 9
salariua
I would look into code injector. Have you condered having the rules and forms on external path maybe.
http://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tri...
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 9
in reply to: salariua
The code injector is a great project an helps me a lot. But this is only for the iLogic code and the triggers and not for the Forms.
Message 4 of 9
salariua
Yes, I agree so that's why I asked you if you can have the form as external. Would that be an option in your case?
Adrian S.
blog.ads-sol.com
Message 5 of 9
Sorry, misunderstand the question...
It could be a way to set the Form(s) as global, but where is the saving Path of the global Forms, and could it set to a network path as well?
Message 6 of 9
salariua
Yes, we have it on a mapped network drive. Need to set it up in options ilogic configuration.
Adrian S.
blog.ads-sol.com
Message 7 of 9
Ahh... some things are so easy and you didn´t see them. The global Forms are saved in the DesignData folder.
Thank you very much for open my eyes Smiley Wink
Message 8 of 9
VdVeek
Stefan, I wrote a blog last year about copying global forms to an other computer. Maybe you can find some information in there: copy-global-forms-to-other-computers/
To find the folder where your form is saved Right click in the Global Forms window and choose “Open Containing Folder”. At this point i can't check if it's posible to set a network path for your global forms.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 9 of 9
in reply to: VdVeek
Rob,
the Path for the global Forms is in the Inventor Design Data folder. For this, we still use a network path. So at the moment you create a new global Form, everyone connected to the Desig Data folder get´s this Form. The possibility for using a network path is given.
Stefan
