Hi guys, I need some help. I'm copying a CC beam to a custom library, but the weight is in pounds and I need it in kg. Can someone help me please?
Solved by pcrawley. Go to Solution.
If it is just for the drawing, you probably already know about forcing the Parts List to "Apply Units Formatting".
If you want the properties of the CC part files to be kg's, then you have a couple of steps to take:
Assuming you have already published the beam to CC:
That's it - Try placing the beam and check the units.
If you're happy with the result, you can delete the file you saved in step 3. You only created it to give CC a template to import.
