Inventor Forum
Cone as split tool again
4 REPLIES 4
190 Views, 4 Replies
Okay, the first model didn't work out, so I'm on my second try. I cannot get IV to select RevolutionSrf2 as the split tool to split ExtrudeSrf9. Can anyone get this to work? -Mike
4 REPLIES 4
Well, I tricked IV into removing the unwanted part of the surface, but I could never get it to select that RevolutionSrf2. Now I have the problem that IV won't mirror, nor revolve the thickened feature that I created from my surfaces. Any ideas on any of this? -Mike "mpower" wrote in message news:406492b6_2@newsprd01... > Okay, the first model didn't work out, so I'm on my second try. I cannot > get IV to select RevolutionSrf2 as the split tool to split ExtrudeSrf9. Can > anyone get this to work? > > > -Mike > > > >
Splits normally over here. Have you restarted maybe and checked to make sure only one inventor.exe is running in process? ~Larry "mpower" wrote in message news:40649f8d_1@newsprd01... > Well, I tricked IV into removing the unwanted part of the surface, but I > could never get it to select that RevolutionSrf2. Now I have the problem > that IV won't mirror, nor revolve the thickened feature that I created from > my surfaces. Any ideas on any of this? > > -Mike > > "mpower" wrote in message > news:406492b6_2@newsprd01... > > Okay, the first model didn't work out, so I'm on my second try. I cannot > > get IV to select RevolutionSrf2 as the split tool to split ExtrudeSrf9. > Can > > anyone get this to work? > > > > > > -Mike > > > > > > > > > >
>Icould never get it to select that RevolutionSrf2. Now I have the problem that IV won't mirror, nor revolve the thickened feature that I created from my surfaces. Any ideas on any of this.
On the first problem try switching the selection order - change selection to face and select the face to split and then change to split tool selection and select cone surface as the split tool. I have never seen this before, but it works to reverse the selection. Lesson learned - try everything.
The second problem, I don't think it is possible to use secondary operations line mirror or pattern on surfaces or features created from surfaces.
J.D.
You are right! I can use the RevolutionSrf as the split tool if I first select the faces to split, then select the split tool. Bummer on the mirror. Thanks.
