Hey guys,
I am making a wheel in Autodesk Inventor 2014 and there are some extrutions within it that I want to delete, I have been told I should use the combine tool but t selects two things at once and i'm struggling. please see if you can help!
Thanks!
As you can see in the screenshot I want to delete the yellow extruded bits.
Thanks for replying!
Will do!
I have tried to only select what I am supposed to but they just join together as a base. As for the tubes they are somehow interlinked with the rim so wont allow me to remove it unless it takes the rim with it.
Attach your *.ipt file here and end all doubt.
Have you installed the latest Service Pack and Update for your version of Inventor?
Even though I attached a possible "solution" - you are going about this all wrong.
Another example.
