Inventor Forum
Classic UI in Inventor 2012??
7 REPLIES 7
Message 1 of 8
binuvarkey
3990 Views, 7 Replies
My computer got stuck while working in Design Assistant 2012 (AutocadM 2012, Inv 2012, Excel 2010 and Outlook 2010 were also open). I had to hard reset and restart. After restarting opened AutocadM and Inventor at the same time. Opened Design Assistant 2012 and found some files needs migration. closed Inv and opened Tak Scheduler. Converted files. Opend Inventor. Voila, Inventor opened in Classic UI. See attached screen captures.
Any comments from anyone else? This is a new PC with Win 7 64bit and Office 2010. No previous version of Autodesk software on it.
7 REPLIES 7
Message 2 of 8
blair
in reply to: binuvarkey
Sweet!
Delta Tau Chi ΔΤΧ
Message 3 of 8
This can happen when the Task Scheduler process itself crashes or got terminated in the middle of finishing a task.
After that, the next Inventor session will be set to Classic UI.
By the way, if you set back the Ribbon UI, in the Application Options, Colors tab, Interface Style and restart Inventor, you should get the Ribbon back (but, I’m sure you’ve already done it).
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
Message 4 of 8
Yes you can add it in regedit too pop up classic interface in Options tab HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion16.0\System\Preferences\UIStyle InterfaceStyle =1 Johan
Message 5 of 8
in reply to: alessandro.gasso
Why can we not comments in blogg http://beinginventive.typepad.com alessandro good tups on the blogg. Johan
Message 6 of 8
alessandro.gasso
Hi Johan,
I’m not sure I got your last comment.
Is it related to this post or to the Blog in general?
Thanks and regards,
Alessandro
Alessandro Gasso
Autodesk, Inc.
Message 7 of 8
To the Blog in general http://beinginventive.typepad.com (This was the way to contact you ....to say it .....) Johan
Message 8 of 8
alessandro.gasso
Ok, got it!
I’ll report the problem to the site administrator asking for fixing the problem.
I apologize with the others involved in this post that are receiving notifications unrelated with the topic of the post.
Thanks and regards,
Alessandro
Alessandro Gasso
Autodesk, Inc.
