Inventor Forum
Circular Pattern
13 REPLIES 13
Message 1 of 14
711 Views, 13 Replies
Circular Pattern
I`m trying to add a circular pattern to my extruded cylinder. My goal is to get 0,5 mm holes in a circle pattern with 14 in placement and 360 degrees. When I add the circular pattern, nothing happens other than the circular pattern feature added to the browser.
Can someone please look into my file and maybe tell me how to solve this.
Thanks in advance!
13 REPLIES 13
Message 2 of 14
cbenner
Please try to always mention the Version of Inventor in your posts that contain parts.  I am guessing this was done in 2014?  This way you'll get the right people helping you out.  For example, I can't open your model since I'm still on 2013.
Anyone on 2014 want to take a look?
Message 3 of 14
in reply to: cbenner
Sorry about that. Yes, its the 2014 version.
Message 4 of 14
mdavis22569
Like this: http://a360.co/1jYWti4
Mike Davis
Message 5 of 14
JDMather
You logic does not make sense to me.
The hole is in the center of the cylinder?
Message 6 of 14
in reply to: mdavis22569
Not quite what I had in mind. I want to have the same pattern as the one on the image below. (Found on the internet)
Thanks for helping!
Message 7 of 14
mdavis22569
Ok ...same principal of what I did ..but make the B/C in the required distance ...and array that line of 8 holes around the Y axis 14 times
Mike Davis
Message 8 of 14
mdavis22569
http://a360.co/1oqx3Mu like this
Mike Davis
Message 9 of 14
Thank You!
Message 10 of 14
JDMather
Something like this?
Michael solution looked too much like work to me!
R2013 solution for ChrisB
Message 11 of 14
mdavis22569
I didn't fully constrain it ... however You can vertical constrain all of them to the mid point ... Pick the size of the BC you need and array/adjust as needed Glad that worked for ya
Mike Davis
Message 12 of 14
in reply to: JDMather
How did you do that in details?
Message 13 of 14
JDMather
It is all in the feature tree.
And here
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Message 14 of 14
Thank you for all your help! Have a nice evening:)
