Hi there members of the community,
These are 2 flanges made in sheet metal.
As you can see in the image below, the distance between the two faces is 14,36mm. Is there an option to change that? E.g. in my case I want to adjust that distance to 21mm.
Solved by CCarreiras. Go to Solution.
Hi!
It depends on how you did the part.
Can you share the file?
...Anyway... it's possible to control the dimensions better for this kind of parts, using this method:
