Inventor Forum
Blurring text
5 REPLIES 5
440 Views, 5 Replies
Blurring text
So I have a text embossed on a surface. I want to blur this text meaning, that there are no sharp edges of the embossed text anymore but a more fluent connection. Basically what curvature does(Press F). But curvature tries to find the same radius for every part of the embossed text and cannot find a common denominator for radius. In other words like a greyscale depth map with white text on black background becomes more one with the background by blurring it in 2D and therefore bringing top and bottom of the embossed text together. See picture.
5 REPLIES 5
Cadmanto
Have you tried just adding chamfers or fillets to the text edges?
How much text are we talking?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
That's exactly what I tried. I've the german version so the translation is different. Just try it with smaller text and you'll never find a suitable radius.
mcgyvr
Can you use "extrude with taper" instead of emboss?
Or maybe "decal"
Cadmanto
I don't understand why the German version would be different, but I will take your word for it.
While I am not much of an iLogic guru, when it comes to odd things like this with no visible solution, makes me wonder if iLogic would work to give you the desired results.
Best Regards,
Scott McFadden
