Is this a test question?
What happens if you expand the node?
What happens if you right click and Open?
You posted the same image twice?
Click on the + symbol to exand and post an image of that.
What happens if you right click and select Open?
Sorry JD, i didn't understand.
I thought the image of the browser icon was enought.
Here the two screenshots:
1)expanding node
2)opening it apart
For a monent I thought I was having a flashback to Inventor Beta 2009 with all the blue icons.
Post the part so we can look at it.
Its a substitute part. Just create a substitute LOD from within an assembly and you'll get a blue part/assembly icon.
Sorry JD if I've spoilt your fun, but someone had to answer this 🙂
Pleasure. You can mark my answer as the solution - and give Kudos if you like. (I've never had any of that so I'm curious to know what it does!)
