Inventor Forum
best method = conversion old .idw to new .dwg template
4 REPLIES 4
PENengr
573 Views, 4 Replies
I want to convert our drawings from one template to another (attached).  Conversion is from .idw to .dwg. What's the best method?
Thanks, Greg
Dell T3500
Intel Xenon CPU
15 MB RAM
64-bit operating system
NVIDIA Quadro 5000
4 REPLIES 4
4donwan4
in reply to: PENengr
You would not be able to convert one file extension to another in sometype of a transfer. If you are just looking to swap out the template information then you can try the "Drawing Resource Transfer Wizard" in the tools menu of the program group.
Don
Curtis_Waguespack
Hi PENengr,
You can use Task Scheduler to convert your IDW files to DWG:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0698-Share_da69...
And then use the Drawing Resource Transfer Wizard previously mentioned, to add or exchange titleblocks, border, sketched symbols, etc.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0725-Tools725/0...
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
couldn't get it to work.
 just exported an inventor blank .idw from inventor as an autocad .dwg
gonna explode that and do it old school. just needed a quick fix but this will take up my day.
oooooosh
just exported as an Autocad .dwg file . Then saved as a model space dwg .
All properties are attributes now, as i wanted.comes in as 3 blocks
1 border
2 title block
3 rev table
I can transfer to paper space at a later date.
