I want to duplicate a solid body 4 times in a part file. i did that by going for circular pattern. But after creating that, i had to add on few more features. I did that in parent solid body. then I noticed that other 3 solid body is not getting updated. I know in assembly file it gets updated but any way in part file.
Solved by SBix26. Go to Solution.
Did you pattern the body or the feature?
Attach your file here.
In the Model Browser, slide the End of Part above the pattern feature, add the new feature(s), then slide the EOP back to the bottom. Or, just drag your already existing new feature above the pattern. If your pattern is of the solid bodies, then this should affect all of them.
