Inventor Forum
anti aliasing problem on new lenovo W530
22 REPLIES 22
Message 1 of 23
GARRYFRASER8394
2295 Views, 22 Replies
So I got a new Lenovo W530 this week, with nvidia k2000 gpu., win7 64bit,
running inventor 2013 and setting hardware tab to "quality" i have some unusual behaviour
The model does anti-alias when static but as soon as I move the mouse the anti aliasing disappears. Once the model is zoomed/panned anti aliasing returns.
I've tried to show this on this (poor) video
http://oregon.smugmug.com/Other/Camera-Awesome-Photos/23904506_thtzpr#!i=1950382634&k=fBhpbkV&lb=1&s...
If I move around with 3D mouse (space explorer) then every think works fine. It's only when mouse cursor moves that anti aliasing breaks.
I've tried 3 different mice and also disconnected everything and tried laptop cursor etc too
I've played with nvidia control panel for ages but those settings seem to have zero impact on inventor,
Does anyone have any advice on where to look to fix this?
22 REPLIES 22
Message 2 of 23
blair
in reply to: GARRYFRASER8394
Most computers ship with old drivers for the graphics card. The first thing I would do is update the graphics card drivers.
Delta Tau Chi ΔΤΧ
Message 3 of 23
GARRYFRASER8394
in reply to: blair
Thanks for the reply,
I did a clean install of windows after getting the PC and updated all the drivers to latest versions, I've also tried an older gpu driver.
W530 has intel hd graphics along with nvidia k2000m discrete
Setting intel gpu in bios only, then inventor actually works fine.
Setting the nvidia gpu only in bios, the same problem recurs.
Message 4 of 23
blair
Try "Compatibility" mode within the Inventor>Applications>Hardware folder.
Delta Tau Chi ΔΤΧ
Message 5 of 23
GARRYFRASER8394
in reply to: blair
Gives the same as performance, anti-aliasing off.
"Software graphics" actually makes anti-aliasing work, but poor frame rate performance etc.
Message 6 of 23
blair
You are back to the "Default" settings in the Nvidia control panel?
Delta Tau Chi ΔΤΧ
Message 7 of 23
GARRYFRASER8394
in reply to: blair
Hi Blair
Yes settings were back to default in nvidia control panel.
I'm now tried the following
lenovo provided drivers
296.79
296.80
296.88
Also tried nvidia verde 301.42 driver but won't install on the k2000m
I've reverted back to lenovo oem hard disk and factory install, reinstalled inventor etc. Problem still recurs. updated all the drivers again but still no improvement.
I just need to find someone else with a new W530 and see if they have same problem...
Message 8 of 23
blair
Try one of the modified drivers from: http://laptopvideo2go.com/
You may need to used one of their modifed drivers to get the latest/current Nvidia drivers. Used to use this site when I had a Dell Precission laptop as I could only install "Dell" drivers on the machine. By using the modified DLL file you can install the current Nvida drivers.
Delta Tau Chi ΔΤΧ
Message 9 of 23
GARRYFRASER8394
in reply to: blair
Had a try and it looks like the k2000m is still to new, I think it's also referred to as 2100m. Either option still isn't listed in the long list of models for the latest 300 series win 7 driver
Message 10 of 23
GARRYFRASER8394
in reply to: blair
laptopvideo2go released version 305.53 with a modded inf last week.
This installs without issue on the W530.
The problem still remains though
Message 11 of 23
blair
Have you tried different settings within Inventor under the Application>Hardware: Performance, Quality, Compatibility.
Delta Tau Chi ΔΤΧ
Message 12 of 23
GARRYFRASER8394
in reply to: blair
Yep, AA only works with quality set, disappears when mouse is moved
Spent last hour playing with nvidia program over rides but doesn't seem to have any effect, apart from causing inventor to crash.
Message 13 of 23
blair
in reply to: blair
Check if you are current on all DirectX from Microsoft?
After that, possibly wait for any drivers or bios updates from the manufacture for your Lenovo.
Delta Tau Chi ΔΤΧ
Message 14 of 23
Hi
I have exactly the same problem with my Nvidia K5000 card.  Move the mouse and no AA.
Is it a K series issue?
Have you tried without the 3D connexxion driver installed?  (I haven't)
My mouse is standard windows 7 driver.
Latest drivers on everything.
Neil.
Message 15 of 23
blair
in reply to: NeilClasby75
Does this laptop have an intergrated Intel GPU as well. If so, go to the Nvidia control panel and make sure it is using the Nvidia GPU and not the on-board Intel GPU
Delta Tau Chi ΔΤΧ
Message 16 of 23
NeilClasby75
in reply to: blair
This is not a laptop but a Dell T5600 workstation using a Quadro K5000 card.  My HP laptop with Quadro 4000M did not have this problem, and I've made sure the Nvidia settings are the same - which was basically default anyway.
I'll check the GPU settings though.
Thanks, Neil.
Message 17 of 23
I wasted many hours on this but it's clearly a driver fauly with the k series of cards.
I now use an ATI card on a desktop for 90% of what I do, only use the laptop when out on site etc.
Nvidia won't be getting any more of my business for business graphics 🙂
If the card is new can you return it?
Message 18 of 23
NeilClasby75
in reply to: blair
Hi
I wouldn't want to get into changing this card.  It's a very newly released card so I assume there will be some teething problems.
I have gone for Nvidia because of problems with my ATI cards.  Perhaps neither are better and each have issues. I'm sure its all pretty complex.
Regards, Neil.
Message 19 of 23
rmerlob
This is exactly the same problem I have on this thread, https://forums.autodesk.com/t5/Autodesk-Inventor/gtx-660-anti-alias/td-p/3762852
It´s really interesting to see youre getting this with a business card. Mine´s a GTX660.
Please post back if you get some leads, I´ll be sure to do so myself.
Message 20 of 23
NeilClasby75
in reply to: blair
Hi Garry
Not sure whether your drivers have been improved and resolved the problem?
The latest drivers for K5000 card still have the problem, although they are gradually improving, such as weird line effect that I had in IDW when on "Quality" setting.  But I've found a work around for anti-aliasing in parts and assemblies.  Just change the view from Default or Two Lights to an IBL environment such as Plain Room.  For some reason the anti-aliasing then hold after mouse movement!  Its a bit of a pain because you can't tell Inventor to automatically load an IBL on all files.  But at least when you are presenting on site you can use it.
Hope this works you for too.  And helps.
Regards, Neil.
