Inventor Forum
Adaptive Part
3 REPLIES 3
bespel
257 Views, 3 Replies
Adaptive Part
i would like to make adaptive (to drive the adaptivity) in this assembly.
The C part is rubber made.
Where am i doing it wrong? I don't understand.
Attached the assembly
Thanks!
bs
3 REPLIES 3
johnsonshiue
in reply to: bespel
Hi! It is a bit unclear to me what kind of adaptive motion you are going after. Do you want the half arc rubber band to deform from an half arc to a half ellipse due to compression? Or, you want it to reduce radius constantly?
Before you start doing adaptive modeling, it is better to clearly define the driver geometry and the follower geometry. Also define how follower geometry will deform by driver. Please let me know a bit more specifics and I should be able to figure out a reasonable solution.
Many thanks!
Software Test Engineer
bespel
in reply to: johnsonshiue
Many Thanks to you Johnson!
This is the scheme, i don't know if is possibile.
Doesn't matter if it's an arc, elipse, lines or spline...the one that will give the better solution during driving adaptivity.
I can't control or understand  the logic of the adaptivity in the sketch..
johnsonshiue
in reply to: bespel
Hi! Attached is a very simple example showing how it can be done using Adaptive. Open the assembly and right-click on DriveMe constraint and click Play button. You will see the Rubberband deforms with the change in DriveMe (anglular constraint).
The trick here is to keep adaptive relationship clear and clean. There are several ways to establish adaptive relationship. Use the most intuitive and logical one. What I did was to create the Base parts (driver) and understand the trigger constraint first. Then worry about creating the Rubberband part. In this case, if you drive more than 10 degree, the Rubberband will collapse due to the two arcs in the adaptive sketch. You can replace them with a spline.
Let me know if you have any question.
Thanks!
Autodesk Customer Advisory Groups
