Inventor Forum
3d DWG to IPT
30 REPLIES 30
Message 1 of 31
10618 Views, 30 Replies
3d DWG to IPT
I have some 3d DWG files (which for some reason the content type is not allowed to attach), and I'd like to convert them to IPT files for use in Inventor. I tried exported to IGES, but when I try to open the exported IGES file, Inventor hangs and I have to give it the ol' Vulcan nerve pinch & restart it.
It would seem to me there has got to be an easy way to do this...
I'm using Inv Suite 2009 SP1.
Thanks!
30 REPLIES 30
Message 2 of 31
JDMather
File Open and set Options.
For more information see
http://www.augi.com/publications/aug...20091008lr.pdf
http://www.myvbooks.com/ac55jsp/stor...EA040C9105FF2C
ML205 (I do not get any compensation from this.)
Message 3 of 31
Thanks JD. The links didn't work (because of the long link name auto-inserted ellipsis) but I was able to search for the AUGI article.
So I am able to open the 3D DWG file in INV, How do I convert it to a 3D solid IPT file?
Message 4 of 31
JDMather
If it is a solid DWG it will automatically be a solid in Inventor.
If it isn't solid DWG, zip and attach here for further instuction or shell out $190 on the second link.
http://www.myvbooks.com/ac55jsp/stores/1/Autodesk_University_2008_Inven_P271C95.jsp?UserID=1252114&ACBSessionID=66C0CBEA040C9105FF2C
Edited by: JDMather on Feb 19, 2009 12:29 PM
Message 5 of 31
OK here it is!
Message 6 of 31
JDMather
Select files of type AutoCAD dwg and select your file name.
Click Options
Chage to Import.
Open
Follow the Import Wizard
Message 7 of 31
Got it - Thanks!
Message 8 of 31
Another issue this morning - while trying to convert a MDT dwg file, I get a message box that says "Mechanical Desktop Part/Assembly translator not registered."
I have the translators loaded in tools>add-ins, so I'm not sure what this means or haw to fix it.
Any suggestions?
Message 9 of 31
"it is a solid DWG it
will automatically be a solid in Inventor. If it isn't solid DWG"
Not quite.... Select the Options in the File open dialog after
selecting the file and set it to IMPORT. Then on the 3d page of the Import
Wizard be sure that 3D Solids in the upper left corner is checked.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing
Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008
SP2, AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440,
Driver: .8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 10 of 31
You must have MDT installed and open to translate. Do not have
the file open in MDT. Then use Import options in IV. IV will take care of the
rest. I will have a tutorial on Translating MDT completed by the end of the
month.
Expert
Autodesk Manufacturing Implementation Certified
Expert.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Message 11 of 31
INV Suite 2008 was bundled with MDT. INV Suite 2009 only has AutoCAD Mechanical, not MDT. The import wizard recognizes the file as a MDT file, but then won't let me import it. So much for legacy drawings - and these are 3rd party.
There has GOT to be an easy way to do this
Does this mean I have to install MDT from the INV 2008 bundle? I'm gonna run out of drive space...
Message 12 of 31
GlennPoorman
You can install the MDT from the 2008 bundle. I believe you should have also received instructions on where to go online for a copy of MDT2009 (which is recommended).
You do need an installed MDT in order to import MDT files. The installed MDT also has to be the last AutoCAD based product run on your machine. I recommend starting it up and then firing off your import in Inventor.
Glenn
Message 13 of 31
You'd think it would be listed under "downloads" in the subscription center. Alas, it isn't. Anyone know where the link for MDT 2009 is?
Message 14 of 31
JDMather
Last time I needed to download MDT 2009 a trivially easy Google search turned up the download url. I haven't checked recently.
Message 15 of 31
Expert
Expert.
PcCillin AV
XP
Message 16 of 31
Thanks Dennis!
Message 17 of 31
I'm not sure if this will help . . . . but here goes. I had a difficult concetina part to create . . . . . radii, angles etc. I couldn't sketch in Inventor. Had to draw it in Autocad (2d) copy and pasted into Inventor ( sketch mode )
Message 18 of 31
JDMather
Attach the file here.
Message 19 of 31
in reply to: JDMather
 Thanks JD Mather,
 I was just answering mooresk257's question for a simple way. I'm better at Autocad than Inventor. I just created a 2d sketch in Autocad and pasted into a 2d sketch document in Inventor. Worked fine. Should also work in 3d if mooresk257
pastes it in a 3d sketch in Inventor. . . . . easy.
My problem is how to make the concertina part work like you would a spring. I've seen a tutorial in solidworks but not Inventor.
Any ideas?
Message 20 of 31
JDMather
@Anonymous wrote:
 Thanks JD Mather,
You did not answer the questioin with an easier way of opening an AutoCAD 3D in Inventor - I suspect your technique is actually much more work - that is why I requested your file that you think is easier to sketch with AutoCAD.
Also, this is a very old thread - I suspect the OP had solved the problem by now.
