Inventor Forum
2014 Pro Crashing at Part Edit
7 REPLIES 7
Message 1 of 8
anderson51
516 Views, 7 Replies
I am experiencing a significant amount of crashing with Inventor Professional 2014. I have installed the Service Pack 1 and it doesn’t seem to be helping. Typically it is happening when I try and edit an .ipt through an iam. Is this a known issue that others are complaining of?
Attached are my computer specs.
7 REPLIES 7
Message 2 of 8
Hi anderson51,
If you go to the Tools tab > Application Options > Hardware tab and set it to Performance or Compatibility does that help?
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-F39A7D5F-86E5-4F48-9313-8303E9A799BA
Also, make sure you have the latest service pack and hotfixes installed:
http://knowledge.autodesk.com/support/inventor-products/downloads#?rows=10&sort=score
I hope this helps.
Curtis
Message 3 of 8
blair
in reply to: Curtis_Waguespack
Try changing to a different USER Log-In. Preferably one with Admin Privileges. If I am working in a IAM file and creating a number of new parts within the IAM and don't do a save to actually save the new parts, Inventor will become unstable. The first save is really important to it's stability.
Delta Tau Chi ΔΤΧ
Message 4 of 8
anderson51
in reply to: blair
Thanks Blair,
When you say change to a User with Admin privileges....are you meaning Windows user?
Message 5 of 8
blair
in reply to: anderson51
Yes, If you already have Admin Priv, try a different user. This will also determine if your Profile in Windows has become corrupt.
Delta Tau Chi ΔΤΧ
Message 6 of 8
mcgyvr
in reply to: blair
and of course its always a good suggestion to ensure you are on the latest graphics card driver... Not the Autodesk certified list junk.. The lastest from the cards manufacturers website.
Message 7 of 8
johnsonshiue
Hi! Did you submit crash reports when Inventor crashed? If yes, please let me know what email address you submit the reports with. Many thanks!
Software Test Engineer
Message 8 of 8
anderson51
I did a complete re-install and am now running fine.
Thank you
