Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
415 Views, 5 Replies
Section View Location
I am using ETO 2014 and I am trying to place my section view line a specific distance for the edge of my part. The section line is always centered with the part and I would like the section line to be offset along the x-axis? Does anyone know how to do this? My current code is posted below. Thanks.
Rule sectionViewSketchPoints As List
Dim origin As Point
origin = Front_View.workpointLocation(Front_View.model,"Center Point")
Dim scale As Number = 1/Front_View.viewScale*.53
Dim pt1 As Point
pt1 = origin + Front_View.unitY *Front_View.height * scale
Dim pt2 As Point
pt2 = origin - Front_View.unitY * Front_View.height * scale
Return {pt1, pt2}
End Rule
Child A As :Inside_Left_Section_View
parentView = Front_View
origin = Point(localx(Front_view.origin)+7,localy(Front_view.origin),0)
viewScale = Front_View.viewScale
SketchPoints = sectionViewSketchPoints
FullDepth? =True
SectionDepth =.5
showViewLabel? = False
displayTangentEdges = True
Reverse? = False
End Child
Kenneht Adelman
5 REPLIES 5
AlexKorzun
Hi
Did you try to supply the position in BreakAlignmentPosition Parameter?
If the BreakAlignmentPosition is specified, then 'origin' Parameter is effectively ignored.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
rikard.nilsson
I use math with Vectors to get the points that I need
Take a look at the function Perpendicular() if you want the points to have an offset distance
/Rikard
Guys,
Thanks for the input. I am new at ETO, could you show me an example of how you would solve this dilemma? Thanks.
AlexKorzun
This adds an offset to the right for one of the points:
pt1 = origin + Front_View.unitY *Front_View.height * scale + Vector(10,0,0)
Thank you,
Alex Korzun
rikard.nilsson
I think that it would be perfect if you can add some pictures of what you are trying to achieve and maybe some more describing text.
Rikard
