Does anyone know if Inventor ETO 2015 runs under Windows 8.1, and/or, if it will connect to Visual Studio 2013?
Thanks in advance.
Yves
Solved by MjDeck. Go to Solution.
Solved by mallorn. Go to Solution.
Answer is "Yes" for the first part: Inventor ETO 2015 works on Win8.1 (tested with OEM and ETO Addin)
ETO 2015 won't connect to Visual Studio 2013. The ETO extension for Visual Studio only runs in VS2012. So if you want to develop Intent code in Visual Studio, you have to use VS2012.
