I am trying to get a tolerance to change when I create a dimension in Intent.
The code seems to work if run from the Immediate window but I can not seem to get it to run when the dimension is created.
Can anyone help to figure out what needs to be done to make this work.
Also I cannot seem to get any tolerance types except Deviation and Symmetrical. I can not seem to get the Limits-Stacked to work for example.
I call out a child for a dimension setting a variable (blnSetTolerance?) indicating I want to change the tolerance
Child DIM1 As :CompanyLinearDimension ':IvLinearDimension '
view=ViewA
dimType=:horizontal
part1= viewModel
part2= viewModel
entity1= "plane1"
entity2= "plane2"
centerText?= True
render?=Render? 'True
textOrigin= ViewA.origin + Vector (0,1.75,0)
dimStyle="Dual Dimension"
blnSetTolerance? = True
End Child
CompanyLinearDimension consists of the following iks file.
'! Intent Language(tm) 3.0
Design CompanyLinearDimension : ShaftRoot IvLinearDimension
Parameter Rule blnSetTolerance? As Boolean = False
Uncached Rule changeTolerance As List
If blnSetTolerance? Then
Return addMyTolerance(Me)
'Return addMyTolerance(%%updateSelf)
Else
Return {"NO"}
End If
End Rule
Method addMyTolerance(p As Part) As List
Dim linDim As Any = GetHostObject(p)
linDim.Tolerance.SetToDeviation("0.0125 in", "-0.0950 in")
'linDim.Tolerance.SetToSymmetric("0.0125 in")
linDim.Precision = 4
linDim.TolerancePrecision = 4
''linDim.Tolerance.SetTobasic
''linDim.Tolerance.SetToDefault
''linDim.Tolerance.SetToFits("FitType","HoleTolerance", "ShaftTolerance")
''linDim.Tolerance.SetToLimits("Stacked","0.0125 in", "-0.0950 in")
''linDim.Tolerance.SetToMax ''linDim.Tolerance.SetToMin
''linDim.Tolerance.SetToReference
Return { "Ok" }
End Method
End Design
with some help from Wayne Brill this is my final code to reset the tolerance type and tolerance precision automatically when creating a dimension from within Inventor ETO (intent).
' DESIGN CREATION INFORMATION
'Design Name: TidlandLinearDimension
'Design Intent: a file to add funtionality to ivLinearDimension such as being able to change the tolerance
'Drawing Design Based On:
'Date Created: 10/15/2012
'Created by: Morgan Gardiner
' HISTORY
Design
CompanyLinearDimension : IvLinearDimension
'####### EXAMPLE OF HOW TO CALL THIS DESIGN FROM ANOTHER #####################
'Child SlotStart As :CompanyLinearDimension
' view=ViewA
' dimType=:horizontal
' part1= viewModel
' part2= viewModel
' entity1= "End"
' entity2= "SlotStart"
' centerText?= True
' render?=Render? 'True
' textOrigin= ViewA.origin + Vector (0,1.75,0)
' dimStyle="Dual Dimension"
' blnSetTolerance? = True
' strToleranceType = "Deviation" ' "Default","Deviation","LimitLinear","LimitsStacked","Reference","Symmetric"
' 'intTolerancePrecision = -1
' anyUpperTolerance = "0.125 in" '0.00 'UPPERTOLERANCE CAN BE PUT In As A String WITH UNITS DEFINED Or As A Number And DEFAULT CENTIMETER UNITS IS ASSUMED.
' anyLowerTolerance = "-0.05 in" '0.00 'LOWERTOLERANCE CAN BE PUT In As A String WITH UNITS DEFINED Or As A Number And DEFAULT CENTIMETER UNITS IS ASSUMED.
' 'anySymmetricTolerance = 0.00
'End Child
'A VARIABLE TO DETERMINE IF YOU WANT TO SET/CHANGE A TOLERANCE FORMAT
Parameter
Rule blnSetTolerance? AsBoolean = False
'A VARIABLE TO SET THE TOLERANCE TYPE
Parameter
Rule strToleranceType AsString = "Default"' "Default","Deviation","LimitLinear","LimitsStacked","Reference","Symmetric"
'A VARIABLE TO SET THE PRECISION OF THE TOLERANCE IE. 2 DECIMAL PLACES OR 4 DECIMAL PLACES
Parameter
Rule intTolerancePrecision AsInteger = -1
'A VARIABLE TO SET THE UPPERTOLERANCE ON A RANGE
Parameter
Rule anyUpperTolerance AsAny = 0.00 'UPPERTOLERANCE CAN BE PUT In As A String WITH UNITS DEFINED("0.012 IN") Or As A Number(0.012) And DEFAULT CENTIMETER UNITS IS ASSUMED.
'A VARIABLE TO SET THE LOWERTOLERANCE ON A RANGE
Parameter
Rule anyLowerTolerance AsAny = 0.00 'LOWERTOLERANCE CAN BE PUT In As A String WITH UNITS DEFINED("-0.012 IN") Or As A Number(-0.012) And DEFAULT CENTIMETER UNITS IS ASSUMED.
'A VARIABLE TO SET THE SYMMETRICAL TOLERANCE IF USING THE SYMMETRICAL TOLERANCE TYPE.
Parameter
Rule anySymmetricTolerance AsAny = 0.00 'SYMMETRICTOLERANCE CAN BE PUT In As A String WITH UNITS DEFINED("0.012 IN") Or As A Number(0.012) And DEFAULT CENTIMETER UNITS IS ASSUMED.
'Pulled this from %%IvCommonDimensionMixin and added my rule to it so that it would generate automatically when the dimension was created.
' This should be used for post-create properties for ALL DIMENSIONS
< %%category(
"Inventor Internal") > _
Rule %%setGenericNonIntrinsicProperties AsBoolean
%%setDimensionLayer
%%setDimensionStyle
%%setFirstArrowheadInside
%%setSecondArrowheadInside
'Added to the rule
changeTolerance
'End added to the rule
ReturnTrue
End Rule
Uncached
Rule changeTolerance AsList
Else
Return {"NO"}
EndIf
End Rule
Method
addMyTolerance(p AsPart) AsList
'GET THE CURRENT DIMENSION
Dim linDim AsAny = GetHostObject(p)
'SET THE TOLERANCETYPE IF BLNSETTOLERANCE? IS TRUE
If strToleranceType = "Deviation"Then
linDim.Tolerance.SetToDeviation(anyUpperTolerance, anyLowerTolerance)
ElseIf strToleranceType = "LimitLinear"Then
linDim.Tolerance.SetToLimits(Inventor.ToleranceTypeEnum.kLimitLinearTolerance, anyUpperTolerance, anyLowerTolerance)
ElseIf strToleranceType = "LimitsStacked"Then
linDim.Tolerance.SetToLimits(Inventor.ToleranceTypeEnum.kLimitsStackedTolerance, anyUpperTolerance, anyLowerTolerance)
ElseIf strToleranceType = "Reference"Then
linDim.Tolerance.SetToReference()
ElseIf strToleranceType = "Symmetric"Then
linDim.Tolerance.SetToSymmetric(anySymmetricTolerance)
Else'"Default"
linDim.Tolerance.SetToDefault()
EndIf
'IF THE TOLERANCE PRECISION IS BEING SET BY THE USER TO SOMETHING OTHER THAN DEFAULT
If intTolerancePrecision > -1 Then
linDim.TolerancePrecision = intTolerancePrecision
EndIf
EndIf
Return { "Ok" }
'Tolerance Methods:
' OF NOTE IS THAT UPPERTOLERANCE and LOWERTOLERANCE CAN BE PUT IN AS A STRING WITH UNITS DEFINED OR AS A NUMBER AND DEFAULT CENTIMETER UNITS IS ASSUMED.
'SetTobasic()
'SetToDefault()
'SetToDeviation(UpperTolerance, LowerTolerance)
'SetToFits(FitsToleranceType As ToleranceTypeEnum, HoleTolerance As String, ShaftTolerance As String)
'SetToLimits(LimitsToleranceType As ToleranceTypeEnum, UpperTolerance, LowerTolerance) 'kLimitsStackedTolerance = 31237 , kLimitLinearTolerance = 31238
'SetToMax()
'SetToMin()
'SetToReference()
'SetToSymmetric(Tolerance)
'ToleranceTypeEnum:
'Const kBasicTolerance = 31245 (&H7A0D)
'Const kDefaultTolerance = 31233 (&H7A01)
'Const kDeviationTolerance = 31236 (&H7A04)
'Const kLimitLinearTolerance = 31238 (&H7A06)
'Const kLimitsFitsLinearTolerance = 31242 (&H7A0A)
'Const kLimitsFitsShowSizeTolerance = 31243 (&H7A0B)
'Const kLimitsFitsShowTolerance = 31244 (&H7A0C)
'Const kLimitsFitsStackedTolerance = 31241 (&H7A09)
'Const kLimitsStackedTolerance = 31237 (&H7A05)
'Const kMaxTolerance = 31239 (&H7A07)
'Const kMinTolerance = 31240 (&H7A08)
'Const kOverrideTolerance = 31234 (&H7A02)
'Const kReferenceTolerance = 31246 (&H7A0E)
'Const kSymmetricTolerance = 31235 (&H7A03)
End Method
End Design
