I have Inventor 2014 how can i add the ETO and what do I need to install?
Solved by rikard.nilsson. Go to Solution.
I know that probably this question should be in another area, but I just want to ask you guys that aaree very kind in respond my interest in Inventor.
Can import a file from the traceparts.com instead of building it from inventor? will these parts bring their properties as well?
I also want to learn this tool, of course Inventor then ETO, but is there any book or it's just through this sites, Youtube, and where else?
I just want to find the sequences in how ETO works.
Any suggestion is very appreciated.
Thanks, both you guys,
Sam
Hi again,
I'm not very familiar with TraceParts.com, but what I know is that most of these download sites offers download in what we call a "neutral" forma and not natie Inventor files.And if the format is neutral then there will be no properties in the file. But if they create Inventor files it might contain som information.
To learn Inventor is not easy if you are completly new to 3D-modelling. But if you have some experiance in some other 3D product then it's quite easy.
I allways recommend that you contact a reseller to help you with education. But of course you can find a lot of good stuff on the webb and inside Inventor there are som really good tutorials to guide you into Inventor.
When it comes to ETO.. You are absolutly right about learing Inventor first. And having some skills in programmig is a very good start. VB.NET is the best language because ETO and VB.NET is very simular to each other.
In this page you will find some info..
http://usa.autodesk.com/adsk/servlet/index?id=18361292&siteID=123112
To learn ETO by yourself might be even harder to learn than Inventor and I recommend you to take a course at a resller, Autodesk or some other company that educate in ETO.
/Rikard
Ok, Got it, I feel that I can handle the pressure, I know Autocad, Microstation, Intergraph PDS and SP3D, I like the idea in programming because I develop some Macros in Microstation and in excel, that's why I found ETO. Looking for some tool to develop exactly the "Automate program-software" to get a faster way to create drawings. I definitely will take the courses for ETO. About the traceparts.com, they do have Inventor file as well but I haven't check the properties integrity. I will eventually. Thanks for your advise and comments Rikard.
In my mind you have to learn Inventor first.. Then you understand the ETO language a much better..
I also think it’s better to have someone who knows about ETO to tell you how to get started with the programming. I started by attending to a course held by Autodesk. It was 4 days to learn about the ETO language and after that I sat for some week trying to find out the way how to implement my new knowledge into some real projects.
I was already an API programmer against Inventor so I did not start from scratch with developing and I had used Inventor since release 1.
So my background is a little different from yours.
But one thing that is good to know for you is that making a robust and quite advance configurations in ETO is very simple as soon you get the grip how it’s working.
/Rikard
You can find some training material here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292
Inventor ETO Training Essentials 2016
