I've now refined my iLogic code so it looks like this:
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
'Imports Autodesk.InventorDesignChecker.Main
Imports System.IO
AddReference "C:\ProgramData\Autodesk\ApplicationPlugins\Autodesk Design Checker.bundle\Contents\Windows\InventorDesignChecker.Main.dll"
Public Sub Main
DesignCheckerResultsFromAssembly()
End Sub
Public Sub DesignCheckerResultsFromAssembly()
' Set reference to active document.
' This assumes the active document is an assembly
Dim oDoc As Inventor.AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oSubDoc As Inventor.Document
' Get assembly component definition
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
' Get all occurrences from component definition for Assembly document
Dim oCompOcc As ComponentOccurrence
For Each oCompOcc In oCompDef.Occurrences
' Check if it's child occurrence (leaf node)
If oCompOcc.SubOccurrences.Count = 0 Then
'PART!
oSubDoc = CType(oCompOcc.Definition.Document, Document)
BeginRunDesignChecker(oSubDoc)
Else
'ASSEMBLY!
Call processAllSubOcc(oCompOcc) ' subassembly
End If
Next
End If
End Sub
Public Function GetRootFolder(ByVal path As String) As String
Dim filepath As String = path
Dim directoryName As String
Dim i As Integer = 0
While i < 2
directoryName = System.IO.Path.GetDirectoryName(filepath)
filepath = directoryName
If i = 1
filepath = directoryName + "\" ' this will preserve the previous path
End If
i = i + 1
End While
Return filepath
End Function
' This function is called for processing sub assembly. It is called recursively
' to iterate through the entire assembly tree.
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence)
Dim oSubCompOcc As ComponentOccurrence
For Each oSubCompOcc In oCompOcc.SubOccurrences
If oSubCompOcc.SubOccurrences.Count = 0 Then
'PART!
oSubDoc = CType(oSubCompOcc.Definition.Document, Document)
Else
Call processAllSubOcc(oSubCompOcc)
End If
Next
End Sub
Private Sub BeginRunDesignChecker(ByVal oDoc as Inventor.Document)
Dim projectRootFolder= GetRootFolder(oDoc.FullFileName)
If Not projectRootFolder.Contains("Content Center Files") Then
RunDesignChecker(oDoc)
End If
End Sub
Private Sub RunDesignChecker(ByVal oDoc as Inventor.Document)
Dim iter As ApplicationAddIn
For Each iter In ThisApplication.ApplicationAddIns
If UCase(iter.DisplayName) Like "*CHECKER*" Then
iter.Activate
If odoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
Dim partmgr As Autodesk.InventorDesignChecker.Main.dfmPartManager = New Autodesk.InventorDesignChecker.Main.dfmPartManager(oDoc, ThisApplication, True)
partmgr.activate()
partmgr.ExecuteAllChecks()
Exit For
Else
Dim assyMgr As Autodesk.InventorDesignChecker.Main.dfmAssyManager = New Autodesk.InventorDesignChecker.Main.dfmAssyManager(oDoc, m_inventorApplication, True)
assyMgr.activate()
assyMgr.ExecuteAllChecks()
Exit For
End If
End If
Next
End Sub But even though it "runs" it doesn't appear to affect the DesignChecker results at all.
From my own investigations (as suggested by Philippe) in order to get the "correct" interface I added the InventorDesignChecker.Main.dll as a reference inside a Visual Studio project and having peeked at the internals of it using Reflector I think I'm executing the addin correctly, but it just doesn't make any difference to the overall Check/Failed Check count.
Can anyone shed any light on why that might be?
What would be excellent would be the addition of the source code for this addin to the Exchange Apps package. At least then I (and anyone else) could build it/step through the addin in a debugger to see what it does and when.
Alex.
