Thanks for your input Peter; I have this morning been sent the attached .vb file from my contact at Autodesk.
I've yet to figure out how to integrate this code into my solution, but it looks to be quite useful.
Here's the code for those of you too lazy to download the file:
{code}
Imports Inventor
Imports System.Drawing
Public Class InteractionEventsManager
Dim m_inventorApplication As Inventor.Application
Dim oCornerPt As Point2d
Dim oSize As Size
'Interaction Events
Private WithEvents m_InteractionEvents As InteractionEvents
'Mouse event
Private WithEvents m_MouseEvents As MouseEvents
'Pick event for selecting object
Dim WithEvents m_SelectEvents As SelectEvents
'flag to indicate the mouse is down
Private m_flagMouseDown As Boolean
' start point, for screenshot
Private m_MouseStartViewPt As Inventor.Point2d
'start point, for temporary selecting rectangle
Private m_StartModelPt As Inventor.Point
'flag to indicate screenshot is running
Dim isRunningScreenshot As Boolean
'graphics node
Dim oGiNode As GraphicsNode
'coordinate set for graphics node
Dim oCoordSet As GraphicsCoordinateSet
'color set for graphics node
Dim oColorSet As GraphicsColorSet
'Line strip Graphics
Dim oGiLineStripG As LineStripGraphics
'Line Graphics (for Inventor 2009 only)
Dim oGiLineG As LineGraphics
Public Sub New(ByVal oApp As Inventor.Application)
m_inventorApplication = oApp
oCornerPt = _
m_inventorApplication.TransientGeometry.CreatePoint2d(0, 0)
oSize = New Size()
End Sub
Public Sub DoSelectRegion( _
ByRef bmSize As Size, _
ByRef bmCornetPt As Inventor.Point2d)
StartEvent(True)
bmSize = oSize
bmCornetPt = oCornerPt
End Sub
Public Sub DoSelectObject( _
StartEvent(False)
bmSize = oSize
End Sub
Private Sub StartEvent(ByVal region_or_object As Boolean)
'start interaction event
If m_InteractionEvents Is Nothing Then
m_InteractionEvents = _
m_inventorApplication.CommandManager.CreateInteractionEvents()
Else
m_InteractionEvents.Stop()
End If
m_InteractionEvents.InteractionDisabled = False
If region_or_object Then
'get mouse event
If m_MouseEvents Is Nothing Then
m_MouseEvents = m_InteractionEvents.MouseEvents
m_MouseEvents.MouseMoveEnabled = True
m_MouseStartViewPt = _
m_flagMouseDown = False
End If
Else
'get select event
If m_SelectEvents Is Nothing Then
m_SelectEvents = m_InteractionEvents.SelectEvents
m_SelectEvents.SingleSelectEnabled = False
m_SelectEvents.WindowSelectEnabled = True
End If
End If
m_InteractionEvents.Name = "MyScreenshot"
'start
m_InteractionEvents.Start()
Do While Not m_InteractionEvents Is Nothing
If m_inventorApplication.SoftwareVersion.Major > 13 Then
m_inventorApplication.UserInterfaceManager.DoEvents()
Else
System.Windows.Forms.Application.DoEvents()
End If
Loop
End Sub
Private Sub m_InteractionEvents_OnTerminate() _
Handles m_InteractionEvents.OnTerminate
m_InteractionEvents.InteractionGraphics.PreviewClientGraphics.Delete()
m_inventorApplication.ActiveView.Update()
m_MouseEvents = Nothing
m_SelectEvents = Nothing
m_InteractionEvents = Nothing
End Sub
Private Sub m_MouseEvents_OnMouseDown( _
ByVal Button As Inventor.MouseButtonEnum, _
ByVal ShiftKeys As Inventor.ShiftStateEnum, _
ByVal ModelPosition As Inventor.Point, _
ByVal ViewPosition As Inventor.Point2d, _
ByVal View As Inventor.View) Handles m_MouseEvents.OnMouseDown
'if the interaction event is MyScreenshot,
'then get the view position and model position
If m_InteractionEvents.Name = "MyScreenshot" Then
m_MouseStartViewPt = ViewPosition
m_StartModelPt = ModelPosition
m_flagMouseDown = True
'clean the last graphics
'gi node
oGiNode = m_InteractionEvents.InteractionGraphics.PreviewClientGraphics.AddNode(1)
oCoordSet = m_InteractionEvents.InteractionGraphics.GraphicsDataSets.CreateCoordinateSet(1)
'color set
oColorSet = m_InteractionEvents.InteractionGraphics.GraphicsDataSets.CreateColorSet(1)
Call oColorSet.Add(1, 255, 0, 0)
Dim tg As TransientGeometry = m_inventorApplication.TransientGeometry
Dim tempP As Inventor.Point = tg.CreatePoint(ViewPosition.X, ViewPosition.Y, 0)
oCoordSet.Add(1, tempP)
oCoordSet.Add(2, tempP)
oCoordSet.Add(3, tempP)
oCoordSet.Add(4, tempP)
oCoordSet.Add(5, tempP)
Try
If Not oGiLineStripG Is Nothing Then
oGiLineStripG.Delete()
oGiLineStripG = Nothing
End If
oGiLineStripG = oGiNode.AddLineStripGraphics()
oGiLineStripG.CoordinateSet = oCoordSet
oGiLineStripG.ColorSet = oColorSet
oGiLineStripG.BurnThrough = True
Catch ex As Exception
'a problem in Inventor 2009( R13 ) with
'LineStripGraphics.BurnThrough. Use LineGraphics as workaround
If Not oGiLineG Is Nothing Then
oGiLineG.Delete()
oGiLineG = Nothing
End If
oGiLineG = oGiNode.AddLineGraphics()
oGiLineG.CoordinateSet = oCoordSet
oGiLineG.ColorSet = oColorSet
oGiLineG.BurnThrough = True
End Try
End If
End Sub
' version 2010-05-23: to solve the issue in Perspective View
Private Sub m_MouseEvents_OnMouseMove( _
ByVal View As Inventor.View) Handles m_MouseEvents.OnMouseMove
'if the interaction event is MyScreenshot, draw selecting rectangle.
If m_InteractionEvents.Name = "MyScreenshot" And m_flagMouseDown Then
Dim P1 As Inventor.Point = tg.CreatePoint(m_MouseStartViewPt.X, -m_MouseStartViewPt.Y, 0)
Dim P3 As Inventor.Point = tg.CreatePoint(ViewPosition.X, -ViewPosition.Y, 0)
Dim P4 As Inventor.Point = tg.CreatePoint(P1.X, P3.Y, 0)
Dim P2 As Inventor.Point = tg.CreatePoint(P3.X, P1.Y, 0)
'update coordinates
oCoordSet(1) = P1
oCoordSet(2) = P2
oCoordSet(3) = P3
oCoordSet(4) = P4
oCoordSet(5) = P1
'add line strip
oGiLineStripG.SetTransformBehavior(P1, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling, 1)
oGiLineStripG.SetViewSpaceAnchor(P1, m_MouseStartViewPt, ViewLayoutEnum.kTopLeftViewCorner)
ElseIf Not oGiLineG Is Nothing Then
oGiLineG.SetTransformBehavior(P1, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
oGiLineG.SetViewSpaceAnchor(P1, m_MouseStartViewPt, ViewLayoutEnum.kTopLeftViewCorner)
End If
End If
End Sub
Private Sub m_MouseEvents_OnMouseUp( _
ByVal View As Inventor.View) Handles m_MouseEvents.OnMouseUp
'if the interaction event is MyScreenshot, create the image
End If
oGiLineG.Delete()
oGiLineG = Nothing
End If
'stop interaction event
m_InteractionEvents.SetCursor(CursorTypeEnum.kCursorBuiltInArrow)
'prepare size of the image region, in pixel
oSize = _
New Size( _
Math.Abs( _
ViewPosition.X - m_MouseStartViewPt.X), _
Math.Abs(ViewPosition.Y - m_MouseStartViewPt.Y))
If ViewPosition.X > m_MouseStartViewPt.X And _
ViewPosition.Y > m_MouseStartViewPt.Y Then
oCornerPt = m_MouseStartViewPt
ElseIf ViewPosition.X > m_MouseStartViewPt.X And _
ViewPosition.Y < m_MouseStartViewPt.Y Then
oCornerPt.X = m_MouseStartViewPt.X
oCornerPt.Y = ViewPosition.Y
ElseIf ViewPosition.X < m_MouseStartViewPt.X And _
oCornerPt.X = ViewPosition.X
oCornerPt.Y = m_MouseStartViewPt.Y
Else
oCornerPt = ViewPosition
End If
'take the view position in screen, calculate
'the real pixel data of the corners
oCornerPt.X = View.Left + oCornerPt.X
oCornerPt.Y = View.Top + oCornerPt.Y
End If
End Sub
Private Sub m_SelectEvents_OnSelect( _
ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, _
ByVal SelectionDevice As Inventor.SelectionDeviceEnum, _
ByVal View As Inventor.View) Handles m_SelectEvents.OnSelect
'reserved for future
End Sub
End Class
{code}
I understand that the above code will form part of a plug-in on the Autodesk labs website shortly.
