Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
iLogic Insert OLE Object problem
AlexFielder
Advisor Advisor
Message 1 of 14
AlexFielder
Hi All,
I have the following piece of iLogic cobbled together from various sources:
Dim doc as Document
doc = ThisApplication.ActiveDocument
'Verify the current document has been saved.
If doc.FullFileName = "" Then
	MessageBox.Show("This document must be saved first.")
	Exit Sub
End If
Dim selectedfile As String = String.Empty
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt"
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
oFileDlg.MultiSelectEnabled = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
End If
MessageBox.Show("You selected: " & selectedfile , "iLogic")
Dim oleReference As ReferencedOLEFileDescriptor
If selectedfile.Contains("|") Then ' we have multiple files selected.
	Dim file As String() = selectedfile.Split("|")
	For Each s as String in file
		MessageBox.Show("You selected: " & s , "iLogic")
		oleReference = doc.ReferencedOLEFileDescriptors.Add(s,kOLEDocumentLinkObject)
		oleReference.BrowserVisible = True
		oleReference.Visible = false
		oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1)
	Next
Else
	oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedFile,kOLEDocumentLinkObject)
	oleReference.DisplayName = Mid$(selectedFile, InStrRev(selectedFile, "\") + 1)
End If
 It works fine except that the resultant "3rd Party" folder contains icons with this image:
Instead of the image created when you manually click the "Insert Object" button on the Manage Ribbon -> Insert tab:
Am I missing something which means that iLogic-inserted olereferences aren't treated the same as manually input ones?
Also, when I do this manually, the files are added to Vault Pro 2014 as "children" of whichever file I have run the iLogic within.
Thanks in advance,
Alex.
Replies (13)
Message 2 of 14
AlexFielder
Strange...
I just modified the same ilogic code above to work in vba and lo, it works as expected.
Here's my original source modified to be vba-friendly:
Public Sub addolereferences()
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
    MessageBox.Show ("This document must be saved first.")
    Exit Sub
End If
'Set selectedfile = ""
Dim oFileDlg As Inventor.FileDialog
Set oFileDlg = Nothing
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt"
Call oFileDlg.ShowOpen
Return
End If
'MessageBox.Show("You selected: " & selectedfile , "iLogic")
If InStr(1, selectedfile, "|") > 0 Then
    'If selectedfile.Contains("|") Then ' we have multiple files selected.
    Dim file() As String
    file() = Split(selectedfile, "|")
        For Each s In file
            'MessageBox.Show("You selected: " & s , "iLogic")
            oleReference = doc.ReferencedOLEFileDescriptors.Add(s, kOLEDocumentLinkObject)
            oleReference.Visible = True
        Next
    Else
        oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedfile, kOLEDocumentLinkObject)
        oleReference.Visible = False
        oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1)
    End If
End Sub
the one functional change (which makes no difference in iLogic!) is
 instead of the previous:
Is this a bug or "as intended"? Smiley Embarassed
Message 3 of 14
Vladimir.Ananyev
I get the equivalent results in the iLogic and VBA versions of your rule.
To work correctly in VBA it is necessary to add SET to the both code lines:
Set oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedfile, kOLEDocumentLinkObject)
In my test I added a bitmap image to the drawing sheet. Both properties
oleReference.BrowserVisible = True / False  and  oleReference.Visible = True / False
work as expected.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 4 of 14
AlexFielder
Thank Vladimir, I had forgotten to "Set" the alternating oleReference objects.
That doesn't answer the question as to why code that is functionally identical works when used via vba but not in iLogic?
Message 5 of 14
Vladimir.Ananyev
Strange, I don't see any difference between iLogic and VBA versions.
I used Inventor Prof 2015 SP1 Update 1 (Build 203).
What is your configuration?
Vladimir Ananyev
Message 6 of 14
AlexFielder
Hi Vladimir,
I am using Inventor 2014 Pro SP2 Update 3 (Build 246)
Alex.
Message 7 of 14
Vladimir.Ananyev
Hi Alex,
It looks like the problem with icons in case of iLogic rule has surprisingly simple solution suggested by Mike Deck.
In VB.NET (and thus iLogic), Enum members (constants) must be qualified with their type name.
To find the type name, search for the enum (in Inventor, almost all enum constants start with the letter k)
in the Inventor API help. Searching for kOLEDocumentLinkObject,  you will find the OLEDocumentTypeEnum page.
To help detect these constants in code, you can add the statement
        Option Explicit On
at the top of the rule. This will require that all variables be declared explicitly.
So I've added "Option Explicit On" in the first line, and then added OLEDocumentTypeEnum  qualifier to both constants kOLEDocumentLinkObject.
Other minor changes do not influence to the icons and were added to simplify code a little.
Here is my final version.  This code works both in Inventor 2014 and 2015.
Option Explicit On
'current document
Dim doc as Inventor.Document = ThisDoc.Document
	Exit Sub
End If
'default folder
Dim FolderName As String  = Left$(doc.FullFileName, InStrRev(doc.FullFileName, "\") )
'oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt"
oFileDlg.InitialDirectory = FolderName
Try
	oFileDlg.ShowOpen()
Catch
	Return  'operation was cancelled by the user
End Try
		oleReference = doc.ReferencedOLEFileDescriptors _
			.Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
	Next
Else
			.Add(selectedFile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
End If
The following figures illustrate the difference in results:
Without qualifiersWith qualifier
cheers,
Vladimir Ananyev
Message 8 of 14
AlexFielder
Thanks Vladimir (And Mike) for the solution.
Message 9 of 14
Hi.
I have similar problem.
I make an PDF and DWG drawing of my idw with I logic, that works fine, but then I need to add it manually by Insert object button and so on to get it as a "3rd Party" files in the idw.
What would be the easiest code to add the files with ilogic?
Message 10 of 14
AlexFielder
@Anonymous - not sure why I hadn't seen this reply before now, so apologies for that! For anyone else interested here is my completed Rule:
Option Explicit On
Sub Main()
	'current document
		Exit Sub
	End If
	'default folder
	oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|Other files (*.*)|*.*"
	Try
		oFileDlg.ShowOpen()
	Catch
	End Try
	AddReferences(doc, selectedfile)
End Sub
Public Sub AddReferences(ByVal odoc as Inventor.Document, ByVal selectedfile As String)
			oleReference = odoc.ReferencedOLEFileDescriptors _
		Next
	Else
	End If
End Sub
Message 11 of 14
Jonathanspies
Its an older post but maybe I get an answer here.
I used the rule above to attache pdf/stp/dxf exports to the file. It works fine.
My problem is the following.
When I change something on the drawing i will export the files again and it will automaticlly update the export-files always the same location. With my current rule it always adds new links in the 3rd party section. Can i add a command to the rule which is looking if these Reference is already existing, if so then just cancel and don't add new links?
Option Explicit On
Option Explicit On
Sub Main()
	'current document
	Dim doc As Inventor.Document = ThisDoc.Document
		Exit Sub
	End If
	'default folder
	Dim selectedfile2 As String = String.Empty
	Dim selectedfile3 As String = String.Empty
	Dim oFileDlg As Inventor.FileDialog = Nothing
	'oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|Other files (*.*)|*.*"
	'oFileDlg.InitialDirectory = FolderName
	'oFileDlg.CancelError = True
	'oFileDlg.MultiSelectEnabled = True
	Try
		'oFileDlg.ShowOpen()
		selectedfile = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".pdf"
		selectedfile2 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".dxf"
		selectedfile3 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".stp"
	Catch
	End Try
	AddReferences2(doc, selectedfile2)
	AddReferences3(doc, selectedfile3)
End Sub
Public Sub AddReferences(ByVal odoc As Inventor.Document, ByVal selectedfile As String)
				.Add(selectedfile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
End Sub
Public Sub AddReferences2(ByVal odoc As Inventor.Document, ByVal selectedfile2 As String)
				.Add(selectedfile2,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
		oleReference.DisplayName = Mid$(selectedfile2, InStrRev(selectedfile2, "\") + 1)
End Sub
Public Sub AddReferences3(ByVal odoc As Inventor.Document, ByVal selectedfile3 As String)
				.Add(selectedfile3,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
		oleReference.DisplayName = Mid$(selectedfile3, InStrRev(selectedfile3, "\") + 1)
End Sub
Message 12 of 14
daniel.lundberg8WYSG
Hi AlexFielder.
Thanks a lot for this. I still had this problem daily or weekly but now you have solved it for me!
Me and my colleges will now use this rule. It works perfect!
Message 13 of 14
Jonathanspies
Finally I found out myself how to check if the link is already existing... in case it is there it will delete it
I have now a complete  function which saves PDF,DXF and STP of a drawing and attaches the "Export" files to the drawing. So when I check it into the vault all files are there...
PDF/DXF/STEP Export is not included in the code below...
Option Explicit On
Sub Main()
	'current document
	Dim oleReference As ReferencedOLEFileDescriptor = Nothing
	Dim selectedfilePDF As String = String.Empty
	Dim selectedfileDXF As String = String.Empty
	Dim selectedfileSTP As String = String.Empty
Exit Sub
End If
' Link file
Try
selectedfilePDF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".pdf"
selectedfileDXF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".dxf"
selectedfileSTP = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".stp"
Catch
End Try
	AddReferencesPDF(doc, selectedfilePDF)
	AddReferencesDXF(doc, selectedfileDXF)
	AddReferencesSTP(doc, selectedfileSTP)
End Sub
'PDF-Attachment
Public Function AddReferencesPDF(ByVal odoc As Inventor.Document, ByVal selectedfilePDF As String)
	Dim OLERefPDF As ReferencedOLEFileDescriptor = Nothing
	Dim OLERefsPDF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
		Try
		OLERefPDF = OLERefsPDF.ItemByName(selectedfilePDF)
	            ' File is already attached - delete the attachment so it can be recreated...
	            OLERefPDF.Delete()
		Catch
	            ' The file is not already attached - continue...
	    End Try
		Try
        OLERefPDF = doc.ReferencedOLEFileDescriptors.Add(selectedfilePDF, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
        Catch
        MsgBox("Failed to link to the file", 64, "Export vault")
        Return False
        End Try
End Function
'DXF-Attachment
Public Function AddReferencesDXF(ByVal odoc As Inventor.Document, ByVal selectedfileDXF As String)
	Dim OLERefDXF As ReferencedOLEFileDescriptor = Nothing
	Dim OLERefsDXF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
		Try
		OLERefDXF = OLERefsDXF.ItemByName(selectedfileDXF)
	            OLERefDXF.Delete()
		Catch
	    End Try
		Try
        OLERefDXF = doc.ReferencedOLEFileDescriptors.Add(selectedfileDXF, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
        Catch
        Return False
        End Try
End Function
'STEP-Attachment
Public Function AddReferencesSTP(ByVal odoc As Inventor.Document, ByVal selectedfileSTP As String)
	Dim OLERefSTP As ReferencedOLEFileDescriptor = Nothing
	Dim OLERefsSTP As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors
		Try
		OLERefSTP = OLERefsSTP.ItemByName(selectedfileSTP)
	            OLERefSTP.Delete()
		Catch
	    End Try
		Try
        OLERefSTP = doc.ReferencedOLEFileDescriptors.Add(selectedfileSTP, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
        Catch
        Return False
        End Try
End Function
Message 14 of 14
AlexFielder
I'm glad you figured out a process that works for you, but you know that those three methods are functionally and objectively identical right?
