Hi all 🙂
I can't instal ACAD 2012 - instal stopped with internal error 2738.
I try this http://forums.autodesk.com/t5/Installation-Licensing/Unable-to-Install-ACAD-2012/td-p/2971196 and this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7289987&linkID=9243099 but without effect 😞
Pleas, check ma instal report and try help...
Thx 🙂
Try installing .NET Framework 4.0 manually before running setup again.
Here is a link to the download for the Microsoft .NET Framework 4.0:
For Standalone
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0a391abd-25c1-4fc0-919f-b21f31ab88b7
For Web Installer
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=17851
Good luck!!!
Thx for your tip 🙂
But this step was without effect 😞
Have you any idea, please?
Last setup log
2011/11/7:21:05:57 Martin Vyoral VYOSEK_NTB === Setup started on VYOSEK_NTB by Martin Vyoral === 2011/11/7:21:05:57 Martin Vyoral VYOSEK_NTB Launch 2011/11/7:21:07:25 Martin Vyoral VYOSEK_NTB === Setup ended === 2011/11/7:21:05:58 Martin Vyoral VYOSEK_NTB === Setup started on VYOSEK_NTB by Martin Vyoral === 2011/11/7:21:05:58 Martin Vyoral VYOSEK_NTB Launch 2011/11/7:21:07:27 Martin Vyoral VYOSEK_NTB PageOpen LaunchDialog 2011/11/7:21:08:01 Martin Vyoral VYOSEK_NTB PageOpen LicenseDialog 2011/11/7:21:09:27 Martin Vyoral VYOSEK_NTB PageOpen ProductInfoDialog 2011/11/7:21:09:46 Martin Vyoral VYOSEK_NTB PageOpen ProductSelectionDialog2 2011/11/7:21:09:53 Martin Vyoral VYOSEK_NTB PageOpen FullProgressDialog 2011/11/7:21:09:53 Martin Vyoral VYOSEK_NTB Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1029.exe /q 2011/11/7:21:11:41 Martin Vyoral VYOSEK_NTB Install .NET Framework Runtime 4.0 Language Pack Succeeded 2011/11/7:21:11:41 Martin Vyoral VYOSEK_NTB Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2011/11/7:21:12:42 Martin Vyoral VYOSEK_NTB Install DirectX Runtime Succeeded 2011/11/7:21:12:42 Martin Vyoral VYOSEK_NTB Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/7:21:13:02 Martin Vyoral VYOSEK_NTB Install FaroSDK Succeeded 2011/11/7:21:13:02 Martin Vyoral VYOSEK_NTB Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/7:21:13:29 Martin Vyoral VYOSEK_NTB Install Autodesk Material Library 2012 Succeeded 2011/11/7:21:13:29 Martin Vyoral VYOSEK_NTB Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/7:21:14:07 Martin Vyoral VYOSEK_NTB Install Autodesk Material Library 2012 - Low Resolution Succeeded 2011/11/7:21:14:07 Martin Vyoral VYOSEK_NTB Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\x64\cs-cz\acad\acad.mst;C:\Users\MARTIN~1\AppData\Local\Temp\_AIA738.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Czech\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/7:21:22:16 Martin Vyoral VYOSEK_NTB Install AutoCAD® 2012 Failed Installation aborted, Result=1603 2011/11/7:21:23:26 Martin Vyoral VYOSEK_NTB Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2011/11/7:21:23:59 Martin Vyoral VYOSEK_NTB Rollback Autodesk Material Library 2012 Succeeded 2011/11/7:21:24:05 Martin Vyoral VYOSEK_NTB Rollback FaroSDK Succeeded 2011/11/7:21:24:05 Martin Vyoral VYOSEK_NTB Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2011/11/7:21:24:05 Martin Vyoral VYOSEK_NTB Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted,
Hello everyone. i know this problem and solution too ))) please fallow this steps.
first of all you have to delete the relevant registry entries and re-register the DLL.
Please make sure you back up the registry/system before you make any changes to the registry (how u can look at from microsft official site)
To delete the registry, please run following commands with elevated privileges
On Windows 7/64 bit System
1-) reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
2-) reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
u must delete both
optional if you have 32 bit win7
On Windows 7 32 bit
To Re-register the DLL please run following commands with elevated privileges
make copy+paste one by one
On Windows 7 64 bit System
c:\windows\syswow64\regsvr32 vbscript.dll
c:\windows\system32\regsvr32 vbscript.dll
On Windows 7 32 bit (optional for 32 bit win7)
this step is so important. if u want to solve then you have to trust me. If you had McAfee Antivirus in the past (even if you have unistalled it might leave some trace)
please use this tool to remove it completly.
http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
now intsall again. it will work, be sure )))) if you had activation problem after install then write me again. i know that slotion too...
Best Regard
Osman from Turkey
