Installation & Licensing
Unable to instal ACAD 2012 - Internal Error 2738
5 REPLIES 5
vyoralm
8682 Views, 5 Replies
Hi all 🙂
I can't instal ACAD 2012 - instal stopped with internal error 2738.
I try this http://forums.autodesk.com/t5/Installation-Licensing/Unable-to-Install-ACAD-2012/td-p/2971196 and this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7289987&linkID=9243099 but without effect 😞
Pleas, check ma instal report and try help...
Thx 🙂
5 REPLIES 5
Try installing .NET Framework 4.0 manually before running setup again.
Here is a link to the download for the Microsoft .NET Framework 4.0:
For Standalone
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0a391abd-25c1-4fc0-919f-b21f31ab88b7
For Web Installer
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=17851
Good luck!!!
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. 😉
Thx for your tip 🙂
But this step was without effect 😞
Have you any idea, please?
Last setup log
2011/11/7:21:05:57	Martin Vyoral	VYOSEK_NTB	=== Setup started on VYOSEK_NTB by Martin Vyoral ===
2011/11/7:21:05:57	Martin Vyoral	VYOSEK_NTB	Launch
2011/11/7:21:07:25	Martin Vyoral	VYOSEK_NTB	=== Setup ended ===
2011/11/7:21:05:58	Martin Vyoral	VYOSEK_NTB	=== Setup started on VYOSEK_NTB by Martin Vyoral ===
2011/11/7:21:05:58	Martin Vyoral	VYOSEK_NTB	Launch
2011/11/7:21:07:27	Martin Vyoral	VYOSEK_NTB	PageOpen	LaunchDialog
2011/11/7:21:08:01	Martin Vyoral	VYOSEK_NTB	PageOpen	LicenseDialog
2011/11/7:21:09:27	Martin Vyoral	VYOSEK_NTB	PageOpen	ProductInfoDialog
2011/11/7:21:09:46	Martin Vyoral	VYOSEK_NTB	PageOpen	ProductSelectionDialog2
2011/11/7:21:09:53	Martin Vyoral	VYOSEK_NTB	PageOpen	FullProgressDialog
2011/11/7:21:09:53	Martin Vyoral	VYOSEK_NTB	Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1029.exe /q
2011/11/7:21:11:41	Martin Vyoral	VYOSEK_NTB	Install	.NET Framework Runtime 4.0 Language Pack	Succeeded
2011/11/7:21:11:41	Martin Vyoral	VYOSEK_NTB	Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/11/7:21:12:42	Martin Vyoral	VYOSEK_NTB	Install	DirectX Runtime	Succeeded
2011/11/7:21:12:42	Martin Vyoral	VYOSEK_NTB	Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/11/7:21:13:02	Martin Vyoral	VYOSEK_NTB	Install	FaroSDK	Succeeded
2011/11/7:21:13:02	Martin Vyoral	VYOSEK_NTB	Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/11/7:21:13:29	Martin Vyoral	VYOSEK_NTB	Install	Autodesk Material Library 2012	Succeeded
2011/11/7:21:13:29	Martin Vyoral	VYOSEK_NTB	Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/11/7:21:14:07	Martin Vyoral	VYOSEK_NTB	Install	Autodesk Material Library 2012 - Low Resolution	Succeeded
2011/11/7:21:14:07	Martin Vyoral	VYOSEK_NTB	Installing AutoCAD® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\x64\cs-cz\acad\acad.mst;C:\Users\MARTIN~1\AppData\Local\Temp\_AIA738.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Czech\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/11/7:21:22:16	Martin Vyoral	VYOSEK_NTB	Install	AutoCAD® 2012	Failed	Installation aborted, Result=1603
2011/11/7:21:23:26	Martin Vyoral	VYOSEK_NTB	Rollback	Autodesk Material Library 2012 - Low Resolution	Succeeded
2011/11/7:21:23:59	Martin Vyoral	VYOSEK_NTB	Rollback	Autodesk Material Library 2012	Succeeded
2011/11/7:21:24:05	Martin Vyoral	VYOSEK_NTB	Rollback	FaroSDK	Succeeded
2011/11/7:21:24:05	Martin Vyoral	VYOSEK_NTB	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2011/11/7:21:24:05	Martin Vyoral	VYOSEK_NTB	Rollback	.NET Framework Runtime 4.0 Language Pack	Failed	Installation aborted,
Osi_turk
in reply to: vyoralm
Hello everyone. i know this problem and solution too ))) please fallow this steps.
first of all you have to delete the relevant registry entries and re-register the DLL.
Please make sure you back up the registry/system before you make any changes to the registry (how u can look at from microsft official site)
To delete the registry, please run following commands with elevated privileges
On Windows 7/64 bit System
1-) reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
2-) reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
u must delete both
optional if you have 32 bit win7
On Windows 7 32 bit
To Re-register the DLL please run following commands with elevated privileges
make copy+paste one by one
On Windows 7 64 bit System
c:\windows\syswow64\regsvr32 vbscript.dll
c:\windows\system32\regsvr32 vbscript.dll
On Windows 7 32 bit (optional for 32 bit win7)
this step is so important. if u want to solve then you have to trust me. If you had McAfee Antivirus in the past (even if you have unistalled it might leave some trace)
please use this tool to remove it completly.
http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
now intsall again. it will work, be sure )))) if you had activation problem after install then write me again. i know that slotion too...
Best Regard
Osman from Turkey
radu_and3
Thanks a lot. It works for autocad 13 also.
jakub.kolar
in reply to: radu_and3
Don´t you know, how to solve the same error in windows 8 ?
Administrator Productivity
