Installation & Licensing
Trouble Installing Revit
4 REPLIES 4
359 Views, 4 Replies
I've tried several times to install the Revit dvd on my laptop and it seems to freeze at "1 out of 3" remaining.  Any thoughts on why this might be happening?
4 REPLIES 4
Dwayne.Poot
Hi Iroth76;
   If you can provide the installation log files we can likely narrow down the issue.
dwayne
Dwayne Poot
Support Specialist
Product Support
in reply to: Dwayne.Poot
Hi Dwayne
Thanks for your reply.  The error message I get reads the following: "Error 1305.  Error reading from file D:/x86/RAC2012/Program Files/Autodesk/Root/Program/fbxrenderermr-2_5.dll.  Verify that the file exists and that you can access it."
thanks
Dwayne.Poot
HI Irot76
  I'm assuming that the d:/ drive is a DVD or USB drive. I would try creating a folder on your desktop and copying the contents of d:/ to that folder to ensure that there's no issue or corruption with the drive. Then try to install from the deskopt package
dwayne
Dwayne Poot
Support Specialist
Product Support
Hi Dwayne
OK--I've tried transferring the files from the cd to my computer but it started again to automatically to install.  I received another error message this time.  Here are the notes.
1/1:17:21:32    Lauren Venu    LAURENVENU-PC    === Setup started on LAURENVENU-PC by Lauren Venu ===
2011/11/1:17:21:32    Lauren Venu    LAURENVENU-PC    Launch
2011/11/1:17:23:11    Lauren Venu    LAURENVENU-PC    PageOpen    LaunchDialog
2011/11/1:17:25:17    Lauren Venu    LAURENVENU-PC    PageOpen    LicenseDialog
2011/11/1:17:25:21    Lauren Venu    LAURENVENU-PC    PageOpen    ProductInfoDialog
2011/11/1:17:25:43    Lauren Venu    LAURENVENU-PC    PageOpen    ProductSelectionDialog2
2011/11/1:17:25:55    Lauren Venu    LAURENVENU-PC    PageOpen    FullProgressDialog
2011/11/1:17:25:55    Lauren Venu    LAURENVENU-PC    Installing DirectX® Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2011/11/1:17:29:26    Lauren Venu    LAURENVENU-PC    Install    DirectX® Runtime    Succeeded
2011/11/1:17:29:31    Lauren Venu    LAURENVENU-PC    Installing Autodesk® Revit® Architecture 2012:  TRANSFORMS="D:\x86\en-us\RAC2012\RAC2012.mst;C:\Users\LAUREN~1\AppData\Local\Temp\_AI63E1.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/11/2:12:55:29    Lauren Venu    LAURENVENU-PC    Install    Autodesk® Revit® Architecture 2012    Failed    Installation aborted, Result=1603
2011/11/2:13:20:48    Lauren Venu    LAURENVENU-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
Does this provide any further clues?
thanks!
Administrator Productivity
