Installation & Licensing
Softimage 2011 64-bit will not load
4 REPLIES 4
780 Views, 4 Replies
Trying a new load of this software on a new 64-bit HP workstation. Product fails to load and there is no clear error message. Can anyone at Autodesk provide some guidance on where to start?
4 REPLIES 4
This is the content of the application error in the log
Faulting application name: XSI.exe, version: 9.0.2010.430, time stamp: 0x4bdab71f
Faulting module name: mcp.dll, version: 9.0.2010.430, time stamp: 0x4bdabb3f
Exception code: 0xc0000005
Fault offset: 0x000000000001a2d3
Faulting process id: 0x1338
Faulting application start time: 0x01cb7be5b98a816f
Faulting application path: D:\Program Files\Autodesk\Softimage 2011\Application\bin\XSI.exe
Faulting module path: D:\Program Files\Autodesk\Softimage 2011\Application\bin\mcp.dll
Report Id: 049ade8b-e7d9-11df-83d5-70f395c8bde3
Stephen.Blair
Do you have Digital Persona installed?
If that's not it, it could be a display driver issue.
Here's how to test: http://usa.autodesk.com/getdoc/id=TS14691242
Finally, here's some startup troubleshooting topics from the Softimage KB:
http://usa.autodesk.com/adsk/servlet/ps/search?la=en&siteID=123112&catID=2334116&linkID=12544120&qt=...
Let us know what happens.
// Stephen Blair
// Arnold Renderer Support
Digital Persona was the issue. I was able to launch XSI after killing the process. Thanks!
in reply to: Stephen.Blair
Thanks Stephen, I had the same issue on a HP Elite Book 8570w that had Digital Persona running on it. After I ended the DpAgent.exe & DpAgent32.exe processes in the Task Manager, Softimage 2013 opened.
cheers
Bart
Administrator Productivity
