G'day, first time here on the Autodesk forums.
After buying myself an Intuos4 I went around looking for a decent sketching program to use with it. I found Sketchbook Pro was a favourite amoung many and went over the the Autodesk website to check it out. I found I was able to obtain a free copy of Sketchbook Designer as I am currently in high school. I went for the 2013 edition and downloaded and installed it, but upon opening the program I get this message:
"SketchBookDesigner.exe - Applecation Error
The application was unable to start correctly (0xc000007b). Click OK to close the application."
I'm not quite sure why this problem is appearing as all system requirements match up. I couldn't find any solutions for this issue happening on Sketchbook Designer, but it appears it happens a fair bit on other 2013 editions of autodesk products, after a quick search.
Any help with this issue would be very appreciated.
For now I might download Sketchbook Designer 2012 to see whether I can use that while this problem persists.
Thanks in advance, Tom
@Anonymous wrote:G'day, first time here on the Autodesk forums.
Vedi qua:
http://www.trevisoassistenza.it/guide/17-impossibile-avviare-correttamente-l-applicazione-0xc000007b.htm
Io ho risolto con questa guida, spero possa essere utile anche a te.
