Revit Architecture 2011 will not install because it cannot detect DirectX using SCCM on Windows XP systems
This is a known issue and it is documented in the Installation and Configuration Help. You will need to install DirectX 9 from your Revit Architecture 2011 installation disc. It is located in:
<MediaRoot>\support\DirectX
David Lau
