Good Day All,
My company has a single user license, permanent and no expiry. Because we are on subscription, I had activated my home copmuter on the same license for after hours work. I am now leaving the company next Tuesday and want to remove this license from my home computer.
I want to confirm that when I uninstall PDSU from my home pc, will it remove all associativity from me and my home computer.
If my current employee wishes to activate their license on there new employee's home computer, I don't want them to have to contact me thinking I am stealing there second activation unintentionally...
Thanks for any help!!
Solved by asburyj. Go to Solution.
Hello Sean,
Before uninstall you will want to transfer the license off of you system using the license transfer utility. Details on how to do this can be found in the link below
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
This is perfect, thank you, I now have exported the license from my computer, Inventor is asking for a license when I tried to open it after the exported.
I also checked the box to allow a public export, correct me if I am wrong, but by doing this I allowed the new user that is going to be replacing me, to create there own AutoDesk user name and password and use this license with there own activation?
Thanks again...
The license should not be back available for anyone under the contract to activate and the license is off of your system
