Installation & Licensing
Maya 2014 student serial number not working
3 REPLIES 3
hasaniwalker
1028 Views, 3 Replies
I just installed Maya, but whenever I try to activate it, I get an error message that the serial number isn't valid.  the field for the serial number auto fills on the page btu it says it's not valid.  I also checked the number that was emailed to me, and on the autodesk page, but this copy of Maya 2014 says' it's nto valid.  what should I do to fix this?
3 REPLIES 3
in reply to: hasaniwalker
It should be working if you did everything correctly. Maybe you're overlooking a common mistake? Retrace your steps and check for any silly mistakes. 'Cause I've done this 5 or 6 times on my PCs and it always worked fine for me.
hasaniwalker
I rechecked the number a few times.  It's the same one that was emailed to me.  When I try to activate it the program fills the serial number tab automatically and immediately brings up the error message that the number is invalid.  I sent a message to Maya and they checked the number and said it's not in their system, but I got the serial number from this site, so I'm nto sure why it doesn't work.  hopefully they'll be able to find a solution.
Did you ever find a solution here? I'm having the same issue trying to activate Maya 2014 on my MAC. I read a post about transferring the license from my other PC install. I went through all the steps and when I went to use the License Transfer Utility it never opened. Any help here would be great!
Rebecca!
Administrator Productivity
