This path seems a bit strange:
E:\Documents and Settings\All Users\Data aplikací\Macrovision\FLEXlm\lmgrdl
Where do you actually have lmgrdl located?
What version of FLEXnet do you have installed?
Best Regards, Jimmy Bergmark
Owner/Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
wrote in message news:5238445@discussion.autodesk.com...
Hallo there, i am administrator and AutoCAD user for about 10 years.
I solved lot of problems with my different LM servers before, but this one,
as it seems easy anyway, i can not solve this time.
i have a new LM server (because one of my 2 old ones is "broken" 🙂 and the
second one i had to change to standard user machine). i did install it and
configure services as usualy (as i did many times before), started server -
and sh*t happens.
All i got is server status log in LMTools:
License server status: @OV4XLEKTOR
License file(s) on OV4XLEKTOR: C:\Program Files\AutoCAD 2007\LICPATH.LIC
#this is new server# ;@JANECNTB;E:\Program Files\AutoCAD 2005 CZ;@JANECEK:
#theese are old servers#
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: OV4XLEKTOR
License path: 27000@OV4XLEKTOR
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
computers @janecek and @janecntb does not exist any more in my network, but
i understand it could be listed in some old product licpath on this machine
as i open log file i got this:
15:22:32 (lmgrd) -----------------------------------------------
15:22:32 (lmgrd) Please Note:
15:22:32 (lmgrd)
15:22:32 (lmgrd) This log is intended for debug purposes only.
15:22:32 (lmgrd) In order to capture accurate license
15:22:32 (lmgrd) usage data into an organized repository,
15:22:32 (lmgrd) please enable report logging. Use Macrovision's
15:22:32 (lmgrd) software license administration solution,
15:22:32 (lmgrd) FLEXnet Manager, to readily gain visibility
15:22:32 (lmgrd) into license usage data and to create
15:22:32 (lmgrd) insightful reports on critical information like
15:22:32 (lmgrd) license availability and usage. FLEXnet Manager
15:22:32 (lmgrd) can be fully automated to run these reports on
15:22:32 (lmgrd) schedule and can be used to track license
15:22:32 (lmgrd) servers and usage across a heterogeneous
15:22:32 (lmgrd) network of servers including Windows NT, Linux
15:22:32 (lmgrd) and UNIX. Contact Macrovision at
15:22:32 (lmgrd) www.macrovision.com for more details on how to
15:22:32 (lmgrd) obtain an evaluation copy of FLEXnet Manager
15:22:32 (lmgrd) for your enterprise.
15:22:32 (lmgrd)
15:22:32 (lmgrd)
15:22:32 (lmgrd)
15:22:32 (lmgrd) pid 2860
15:22:32 (lmgrd) Can't open E:\Documents and Settings\All Users\Data
aplikací\Macrovision\FLEXlm\lmgrdl.B2C, errno: 3
15:22:32 (lmgrd) Detecting other license server manager (lmgrd) processes...
15:22:32 (lmgrd) adskflex already running 27000@OV4XLEKTOR
15:22:32 (lmgrd) The license server manager (lmgrd) is already serving all
vendors, exiting.
all i can do is to run AutoCAD 2007 on server - it uses licence and it works
(even as i can not see active licences in lmtools - Perform status enquiry
dialogue box!)
but clients of course got no licence and thats why they can not run it
