Installation & Licensing
License was not obtained Tried Maya 2011 (657C1 2011.0.0.F), error 5
11 REPLIES 11
Message 1 of 12
4347 Views, 11 Replies
I can't figure out what's wrong, i've been searching for a solution for hours now to no avial...
See image
If anyone could offer any solutions, it would be greatly appreciated.
11 REPLIES 11
Message 2 of 12
david.lau
Can you check out the suggestions in this post?
http://forums.autodesk.com/t5/Installation-Licensing/Problem-with-license-License-is-not-obtained/td...
David Lau
Message 3 of 12
in reply to: david.lau
I tried that, and it didn't do anything. Didn't recreate the files, now I just get error 41. So do I put the files back?
Message 4 of 12
david.lau
41 = Product Information Table file is not found.   Can you confirm that you have this file:
C:\ProgramData\Autodesk\AdLM\ProductInformation.pit
David Lau
Message 5 of 12
Well in the link you asked me to try, it says to back-up the files and remove them. When I then tried to reopen maya, I assumed it would try to recreate them and it didn't. So that file is not there, it is however in the back-up folder.
Message 6 of 12
david.lau
Can you move the ONLY the .pit file back in the default location?
David Lau
Message 7 of 12
Well that file is inside the AdLM folder, would you like it so the onlything inside the AdLM folder is the .pit file?
Message 8 of 12
david.lau
I have attached an image.
David Lau
Message 9 of 12
I dont have a cascadeinfo.cas file, I attached a picture of what the folder looks like...
Message 10 of 12
david.lau
I just sent you a private email.  I would like to log a case for you to try to resolve this issue.
David Lau
Message 11 of 12
i got a problem as was discribed in the link http://forums.autodesk.com/t5/Installation-Licensing/Problem-with-license-License-is-not-obtained/td...
and i'm running a Network version. what should i do?
Message 12 of 12
david.lau
Here is the post to setup a network license server on:
Windows
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
Mac
http://forums.autodesk.com/t5/Installation-Licensing/Installing-Maya-2011-2012-with-a-Network-licens...
You then need to edit the C:\flexlm\maya.lic [Windows] or /var/flexlm [Mac] file to point to the license server using Notepad [Windows] or Textedit [Mac].
David Lau
Administrator Productivity
