I can't figure out what's wrong, i've been searching for a solution for hours now to no avial...
See image
If anyone could offer any solutions, it would be greatly appreciated.
Can you check out the suggestions in this post?
I tried that, and it didn't do anything. Didn't recreate the files, now I just get error 41. So do I put the files back?
41 = Product Information Table file is not found. Can you confirm that you have this file:
C:\ProgramData\Autodesk\AdLM\ProductInformation.pit
Well in the link you asked me to try, it says to back-up the files and remove them. When I then tried to reopen maya, I assumed it would try to recreate them and it didn't. So that file is not there, it is however in the back-up folder.
Well that file is inside the AdLM folder, would you like it so the onlything inside the AdLM folder is the .pit file?
I dont have a cascadeinfo.cas file, I attached a picture of what the folder looks like...
I just sent you a private email. I would like to log a case for you to try to resolve this issue.
i got a problem as was discribed in the link http://forums.autodesk.com/t5/Installation-Licensing/Problem-with-license-License-is-not-obtained/td...
and i'm running a Network version. what should i do?
Here is the post to setup a network license server on:
Windows
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
Mac
You then need to edit the C:\flexlm\maya.lic [Windows] or /var/flexlm [Mac] file to point to the license server using Notepad [Windows] or Textedit [Mac].
