During the activation process, there are error appear.
"Your online activation request has returned an error (0) which is not allowing your request to be processed using our automated systems."
Hi louistang,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number so I can further check on it.
Please also include the Request Code so I can manually generate the Activation Code.
H louistang,
I noticed that the Serial Number you sent is still the 2011 version however this has already been Upgraded to the 2013 version.
Would you rather still continue using the 2011 version instead of the 2013 version?
I have try to install the autocad 2013, but the serial number or product key don't match.
Hi louistang,
If you choose to use the 2013 version, you can definitely use it, in fact we encourage you to use the 2013 version as it is the current and newest version.
I will Private Message you the download link for the 2013 version as well as the Serial Number and Product Key.
