Installation & Licensing
Logos_Atum
589 Views, 4 Replies
Language pack coverage
Hello there,
would installing the German language pack
on an international english FDS installation
also install all the German material names?
If not, where are the material libraries located?
I will need to add the German names and cus-
tom materials to the international version of
FDS.
Thanks in advance
Daniel
Dogs aren´t flammable.
4 REPLIES 4
Logos_Atum
in reply to: Logos_Atum
I tried adding the German names directly to
the InventorMaterialLibrary-eng.xlf but it did
not work. I think because of the assigned id´s.
I will try to rename them. Help is very welcome
Logos_Atum
Will changing the "file source language" have the desired
effect? There will be a global rollout and as the assets are
done in a German version there will be trouble using them
on English machines.
If i need to change all the assets to english names, is there
a way to automate this?
Oh my - I see trouble ahead
adsk_loren
In the Inventor \Design Data\Materials folder, there are XLF files with the translated names for each material and color style. The material names should automatically update to the active language.
This is the entry for Chrome in the deu file:
 <trans-unit id="chrome">
        <source>chrome</source>
        <target>Chrom</target>
      </trans-unit>
If you post a sample German file, I'll open it in my English version to confirm it's OK.
Loren
Logos_Atum
in reply to: adsk_loren
Hello Loren,
sorry for answering that late - I´ve been sick for almost a week.
You´re right - they should. I´ve been in touch with Mr. Richter
from Autodesk Munich and we verified this to be an Inventor
issue which will probably be handed over to the development
guys.
Custom appearances work fine as Materials do, but system ap-
pearances simply won´t work as they ought to. I´ve been medd-
ling with the XLF Files too and tried adding as well as changing
source and target values. Won´t do and is undocumented also.
Thanks for your help anyway and have a nice day. Kind regards
Daniel
Administrator Productivity
